Octane exporter for C4D version 0.03
abstrax
Hi all,
as already announced, this is version 0.03 of the exporter to Octane. It adds a material conversion to MTL materials, which will be imported by Octane :)
As OBJ/MTL materials are a very old standard there is only a few things that can be stored in those materials. That means, many parameters of the C4D materials don't get exported. It's just not possible. Octane has also a lot more material parameters than OBJ/MTL materials. That means, to get really nice results you will probably end up tuning most of your materials in Octane. But this shouldn't be a big problem as relinking allows you to change your C4D scene and then update your Octane scene.
So we have two conversion processes here: One from C4D to MTL and one from MTL to Octane which will result in these rules:
- If the C4D material has no reflection, no specular channel and no transparency, it will become a diffuse Octane material.
- If the C4D material has a reflection or specular channel, but no transparency, it will become a glossy Octane materials.
- If the C4D material has transparency, it will become a specular Octane material.
- If a bitmap texture is selected in a C4D material channel, it will be exported using relative image paths. If not, the color of the channel gets exported, if available.
- The color channel of a C4D material becomes the diffuse channel in the Octane material.
- If the reflection channel is enabled, it will be exported as specular channel in the Octane material. If no reflection channel is enabled, the specular channel is used as a fallback, if available.
- OBJ materials can only store a transmissive filter. The transparency color of the C4D material will be stored there. No bitmaps are possible here.
- The refraction index of the transparency channel of the C4D material gets exported, too.
- Alpha channel bitmap and bump channel bitmap will exported, if available.
The plugin does also a reverse gamma correction to compensate color desaturation in Octane due to gamma correction during tone mapping.
There is more to write, but I guess, give it a try. If you have Riptide Pro, I would be very interested in a comparison of the exported materials of the two plugins. The reason is, that the MTL specification is very crude and "unprecise", which made me guess a lot of things. As everyone seems to be happy with the Riptide Pro material export, I would like to use it as a reference.
These are the PC builds of the plugin:
CINEMA 4D R9.6 (32/64bit):
OctaneExport_0.03_win_r9.6_release.zip
(155.69 KiB) Downloaded 509 times
CINEMA 4D R10.1 - 11.0 (32/64bit):
OctaneExport_0.03_win_r10.1_release.zip
(156.08 KiB) Downloaded 514 times
CINEMA 4D R11.5 (32/64bit):
OctaneExport_0.03_win_r11.5_release.zip
(236.29 KiB) Downloaded 587 times
These are the Mac builds of the plugin:
CINEMA 4D R9.6 (32bit):
OctaneExport_0.03_mac_r9.6_release.zip
(102.73 KiB) Downloaded 535 times
CINEMA 4D R10.1 - 10.5 (32bit):
OctaneExport_0.03_mac_r10.1_release.zip
(139.76 KiB) Downloaded 513 times
CINEMA 4D R11.0 (32/64bit):
OctaneExport_0.03_mac_r11.0_release.zip
(285.84 KiB) Downloaded 540 times
OctaneExport_0.03_mac_r11.5_release.zip
(315.24 KiB) Downloaded 578 times
Tomorrow I will do no coding, but after tomorrow I plan to fix any material export problems that have popped up and then start with the animation export.
EDIT: As a lot of people still need support for polygon selections of texture tags and an automatic conversion of non-UVW mapping types to UV mapping, I will focus on this, before I start with animation export.
Happy rendering,
Marcus
mantra
so fast)
MY WORKS
Cinema 4d | Win7x64 | 450gts
russian octane community
http://vk.com/octanerender
iacx
Great! :)
mantra
I do, but after a few hours.
& send you mtl files for comparison
MY WORKS
abstrax
Do that and please send me also the C4D files so that I know, what the source data was.
Thanks a lot for the help. Much appreciated,
Marcus
mantra
ok
MY WORKS
Lemonnado
Thanks! There goes the Sunday ;)
mat536
Thank you.
Take a break you deserve it.
Good stuff.
Mark
Core i7 920 - 2.67 GHz | Win 7 Pro 64Bit - 12 GB RAM | GTX275-896MB - driver v.197.45 | 150 GB Raptor 10K HD | Octane 1.022 beta 2.2 |
Lemonnado
I cannot seem to shake off those artifacts.... Any ideas?
I looked that a similar thread, but that does not contain a hint on how to get that under control in C4D...
I deleted all phong tags and normal tags, optimized the mesh and did ten push ups for no avail...
Cheers
Rainer
ribrahomedesign
hi There
something is wrong here ,i think.
some of my texture maps get exported , some not
in octane the texture witch are not exported from C4d are only displayed as a color,but if i try to reload them again
from inside of octane, nothing happend ,they stay in the color they have been exported from C4d
they seemed to be blocked. i hope this makes sence
Rico
Windows 7 , 64 b / GTX 590 / Archicad 15 , 64 b / Cinema 4D R 13 studio , 64b /Intel(R)Core(TM)Extreme3,20Ghz /always latest Octane.
