Hi Guys,
The problem is that I cannot see the drive anymore.
It does open end close.
I checked the wires, but maybe I should check it better?
What could be the cause?
It used to work a long time ago.
Since it did not work properly I worked around it by using a cd-rom dirve of another PC when needing it.
Now it is getting very annoying and I want to get it working again.
greetings,
cd-rom drive not seen
4090+3089ti & Quad 1080ti
http://www.tapperworks.com
- FrankPooleFloating
Still not working (been 8 days)?...
Does it show up as a drive in Windows Explorer > Computer?.. or in Device Manager (right click on Computer and select Properties)?
A cheap external USB 2 dvd drive is an alternative ($15 on AMZN), if you can't easily get this bad-boy working...
Does it appear in bios?
It may be down. I had similar issue years ago.
Thanx for you response guys,
It still bot working, but I did not try yet.
I will follow your suggestion and get back here with result.
Now the thing is that my other PC also does not have a cdrom available,
because I left it out when transforming my old PC from the old case to a new one.
I left it out, because I want a maximum airflow and now Ihabe a third fan doing his job with no cd drive being in the way for the airflow.
Now I have three pc'c.. One without cdrom hardware, and another does not work, and the third one is OK
I use 'the one' shared over network when I need something to install with dvdrom.
Now here almost is the question...
If I would need to reinstall windows 7 on a PC without cdrom... How should I do that?
Cheers,
Cheers,
If you do go external USB, I think most newer BIOS allow you to set USB devices as (first) boot device for installing Windows etc.. er.. right guys?
I've dropped CD/DVD drives few years ago =) having emergency ready USB drive with bootable windows installation & some nesecary drivers to start with is a good choise =) & it takes way less time to install from usb =) just don't get USB3 as some motherboards read them only after You instal driers =) USB2 is enough & will give You more space for the same price =)
+1glimpse wrote:I've dropped CD/DVD drives few years ago =) having emergency ready USB drive with bootable windows installation & some nesecary drivers to start with is a good choise =) & it takes way less time to install from usb =) just don't get USB3 as some motherboards read them only after You instal driers =) USB2 is enough & will give You more space for the same price =)
Thanx guys,
Good tip.. I will go for external USB.
you guys make life easy
cheers,
cheers,
