octane increase time render (x10) in the middle of animation
- borisrabant
octane have rendered 600 frame without pb. It's very strange !
							Mac pro 2,26 - 8 cores - OS 10.9 - 4 x gtx 780, 1 x gtx 580 - netstor PCI extension
C4D 15 - octane for c4d 2.12.1
if it happens again, check Console output for export times. If you see interesting stuff please notify me. I'm not sure where is the time loss, on export or rendering. Also try to check gpu usages while rendering this frames.borisrabant wrote:octane have rendered 600 frame without pb. It's very strange !
- borisrabant
The new render was done without pb. If I didn't have the screenshot of the first render I would think I'm crazy
- borisrabant
I've made a test. I save copy the same and make another render. Same problem at frame 191.
Here is the log :
---- FRAME 189 DOC:0x0000000145390DC0 first:0 fullUpd:0 updMthd:0 nodes:36 links:4 ----
Tried to access null item
---- FRAME 190 DOC:0x0000000145390DC0 first:0 fullUpd:0 updMthd:0 nodes:36 links:4 ----
---- FRAME 191 DOC:0x0000000145390DC0 first:0 fullUpd:0 updMthd:0 nodes:36 links:4 ----
Is "Tried to access null item" normal ?
							Here is the log :
could you check gpu's? Also please see render image's bottom for info. Let's compare ms/sec values
- borisrabant
gpu-z doesn't see any cuda device
 So I can't check Gpu.
I'm making render to check ms/sec
You could fill in the information on your signature (like the other users) in order to help on situations like these. Which GPU are you using?borisrabant wrote:gpu-z doesn't see any cuda deviceSo I can't check Gpu.
Win 8.1 Pro 64-bit| i7-4930k 3.4GHz | 32 Gb RAM | GTX 980 4Gb| Driver Version 344.75
						- borisrabant
Done
- borisrabant
It seems you were right ! I've disable app nap on octane and C4D (cmd i on each app) and I've rendered 3 different old projects without problem.
Thanks a lot.
							Thanks a lot.
