Hi pBarrelas,
please check that your LOCK icon is pressed on R16. For stats, try to click upper half area of LV to cycle the info boxes.
Version 2.12.2 - final (updated on 18.11.14)
No I didn't had the Lock icon pressed on. I right clicked on LV and select Toggle Info. This solved the problem.aoktar wrote:Hi pBarrelas,
The weird thing is that after reopening the scene in R16, got rid of the offset problem...weird!
Win 8.1 Pro 64-bit| i7-4930k 3.4GHz | 32 Gb RAM | GTX 980 4Gb| Driver Version 344.75
it's related with you sizing of background. Output resolution can be bigger than LV and background looks different than R15. In R15, Lv had not pressed "LOCK BUTTON". I hope that all is clear now for youpBarrelas wrote:Locking to the output resolution can hide the stats?
Yep, crystal!!aoktar wrote:it's related with you sizing of background. Output resolution can be bigger than LV and background looks different than R15. In R15, Lv had not pressed "LOCK BUTTON". I hope that all is clear now for youpBarrelas wrote:Locking to the output resolution can hide the stats?
Thanks a lot!
yeah, at the begining, the behavior of it was weird to me too. Not a must but would be nice if it's fixed to the bottom (of window, not the image) independent of the output size.it's related with you sizing of background. Output resolution can be bigger than LV and background looks different than R15. In R15, Lv had not pressed "LOCK BUTTON". I hope that all is clear now for you
http://www.sadece.com.tr
i7 990x // 12GB Ram // 2x Titan X + Titan + 780 // Octane for C4D // Win7 x64
Yes I definitely agree with you!sadece wrote:yeah, at the begining, the behavior of it was weird to me too. Not a must but would be nice if it's fixed to the bottom (of window, not the image) independent of the output size.it's related with you sizing of background. Output resolution can be bigger than LV and background looks different than R15. In R15, Lv had not pressed "LOCK BUTTON". I hope that all is clear now for you
Can't understand. Are you talking about Stats? It's fixed to bottom and not depended from "LOCK" paramater. I suppose that there is some confusion on you.sadece wrote:yeah, at the begining, the behavior of it was weird to me too. Not a must but would be nice if it's fixed to the bottom (of window, not the image) independent of the output size.it's related with you sizing of background. Output resolution can be bigger than LV and background looks different than R15. In R15, Lv had not pressed "LOCK BUTTON". I hope that all is clear now for you
Sorry, i needed to point "PV" not the "LV" here is what i meant in the attachment.Can't understand. Are you talking about Stats? It's fixed to bottom and not depended from "LOCK" paramater. I suppose that there is some confusion on you.
