Version 2.12.2 - final (updated on 18.11.14)
Hi pBarrelas,
please check that your LOCK icon is pressed on R16. For stats, try to click upper half area of LV to cycle the info boxes.
pBarrelas
aoktar wrote:Hi pBarrelas,
No I didn't had the Lock icon pressed on. I right clicked on LV and select Toggle Info. This solved the problem.
The weird thing is that after reopening the scene in R16, got rid of the offset problem...weird!
Win 8.1 Pro 64-bit| i7-4930k 3.4GHz | 32 Gb RAM | GTX 980 4Gb| Driver Version 344.75
I can see the "LOCK BUTTON" that's actived.
pBarrelas
Locking to the output resolution can hide the stats?
pBarrelas wrote:Locking to the output resolution can hide the stats?
it's related with you sizing of background. Output resolution can be bigger than LV and background looks different than R15. In R15, Lv had not pressed "LOCK BUTTON". I hope that all is clear now for you
pBarrelas
Yep, crystal!!
Thanks a lot!
sadece
yeah, at the begining, the behavior of it was weird to me too. Not a must but would be nice if it's fixed to the bottom (of window, not the image) independent of the output size.
http://www.sadece.com.tr
i7 990x // 12GB Ram // 2x Titan X + Titan + 780 // Octane for C4D // Win7 x64
pBarrelas
Yes I definitely agree with you!
Can't understand. Are you talking about Stats? It's fixed to bottom and not depended from "LOCK" paramater. I suppose that there is some confusion on you.
sadece
Sorry, i needed to point "PV" not the "LV" here is what i meant in the attachment.
Return to “Releases”
