Problème lissage avec un Morph
EBD3D
hello,
Smoothing problem with an activated morph, when disabled all function well.
Thank you.
juanjgon
Do you have also this problem if you render the scene with F9 or if you reload the scene in the IPR after adjust the morph slider?
EBD3D
Only in IPR even if "reload" the scene after ajust the morph, f9 works well.
This is not a problem too, but IPR is also useful in the work.
Thank you Juanjgon ;)
-Emeric
juanjgon
Can you send to me this scene, or a simple scene with this problem, to test it here?
EBD3D
This is the scene with layers and morph.
-Emeric
SCENE_OTOY.rar
(117.18 KiB) Downloaded 231 times
juanjgon
EBD3D wrote:This is the scene with layers and morph.
-Emeric
Thanks, I will check it as soon as possible.
sigmamoon
-Emeric
hello
j ai regardé ta scene, en effet on a ce probleme dès qu on ouvre l ipr
mais dès que tu lances un rendu puis tu ré ouvres l ipr le probleme disparait. L ipr montre le bon lissage qu a ce moment la.
je ne vois pas pourquoi par contre
I have looked at your scene, in fact this problem is as soon as you open the ipr just after to load the scene.
but as soon as you make a render then you re activate the ipr the problem disappears. The ipr shows good smoothing.
i dont know why for now
WebSite compagny
Pixel De Lune
WebSite personnal
SIGMAmoon.com
EBD3D
Bonjour ;)
Merci pour l'info, c'est vrai que ça marche une fois qu'on fait un rendu puis qu'on ouvre a nouveau l'IPR.
Sinon, je n'ai pas rencontré d'autre problème pour l'instant.
Merci
juanjgon
Can you please check this scene with the last daily build 2.13.0? ... I am testing this problem and now all works fine using the last release.
EBD3D
Bonjour Juanjgon,
Nothing has changed.
Works as before, F9 then make it work in the IPR
Sorry ;)
Return to “Lightwave 3D”
