OctaneRender™ Standalone 2.12.1
smicha
:o :shock: :D
PMC speed increased from 9.43ms/s (2.11.1) to 21.80ms/s (2.12). Where is the trick?
abstrax
smicha wrote::o :shock: :D
2.11 was too slow. Compare with 2.06 and 2.10 and you see what I mean.
smicha
Right. 2.06 scores 25ms/s; 2.12 almost the same with path term power set to 1. Thanks Marcus.
smicha
aLeXXtoR wrote:
Rikk The Gaijin wrote:Oh, I forgot, I like the new compact interface! 8-)
Oh, yes! Me too! :)
It's great!
smicha
Thank you so much for implementing the batch rendering LUA!
kavorka
Thank you for everyone that worked on the Batch script :)
The scroll feature is sooo useful.
The only thing that I think needs to be fixed is the output folder dialogue box. Would be good to be able to have it be the standard windows explorer so it is easier to navigate to where we want to save it out.
virtualzapp
On Mac, I can't open the standalone version 2.12 (back in 2.06).
Indeed it gives a file error at launch without possibilities to do anything than click ok and it closes… (cf attached screenshot)
Cheers
Regis
Screen Shot 2014-10-24 at 10.14.49 AM.png (12.07 KiB) Viewed 3932 times
VFX compositor / CG generalist
Mac Pro 12C 2.93GHz, 64gb ram, 1xGTX Titan X, 4xGTX Titans in Cubix
nardo
Hi, can I disable the 'ctrl+alt+Z/Y' shortcut for undo/redo?
my usual shortcut is ctrl+Z/Y, or should there be an option?
windows 8 SP1 | i7 2600k | 8G DDR | 1xGTX 690 1xGTX Titan | Rhinoceros
PolderAnimation
"Added render pass support in Lua:"
thnx guy's!
Win 11 | Dual RTX 5090 | AMD Ryzen 9 9950X| 192GB
abstrax
virtualzapp wrote:Hi,
Cheers
Regis
Which Mac OS are you using?
