OctaneRender™ for Blender 2.06 - 6.4 Win [OBSOLETE]
JimStar
OctaneRender™ for Blender plugin. Windows x64 version.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one. To stop the server - just right-click its icon in the tray.
  • Fixed bug: crashed in some cases when adding new image texture during Live-Render active.
  • Reworked translation of modified geometry (to address the bug reported by aLeXXtoR).
Blender Octane Edition - 6.4 (2.72) (64.9MB autoinstaller file)
Octane Server - 2.06 - 6.4 (8.9MB autoinstaller file)
DEMO is available. Use the same Octane edition of Blender for DEMO version of OctaneServer.
Octane Server DEMO - 2.06 - 6.4 (8.0MB autoinstaller file)
aLeXXtoR
Yes, it seems to be ok now! Thank you, JimStar! :)
Win 10 Pro 64bit | GeForce RTX 2070 SUPER 8Gb | AMD Ryzen 7 3700X | 32GB RAM
WebSite
Showreel
Garquitectos
Hi, I have problems with .png textures, the same material with the texture save as jpg works fine... Anybody can test it?
Thanks.
Octane Render for Archicad, Archicad 16 Spanish, Bimx. - Win 7 64 bits - Intel core i7 870 - 3,30 Ghz, - 12 Gigas Ram - GTX 660 + GTX 650 Ti
http://www.garquitectos.es
http://garquitectos.wordpress.com/
Garquitectos
The problem with png are only with the octane server demo.. not in the standard version :D I make the test with the same file in my house (standar edition) and works perfectly... in the work with the demo it didn't work.
aLeXXtoR
Emm... What a kind of problem are you talking about?..
WebSite
Showreel
Elonius
Hi, I think I've found a bug. Border rendering is actually slower than non border rendering. Isn't border region rendering supposed to be faster?
I've attached an image so you can see what I am talking about. Also, why is non border rendering noisier at the same amount of samples?
Render speed test
Render speed test
RajivMudgal
The hair works fine
Rajiv Mudgal
Film Maker and VFX Creative Director at DarkWhite Productions
Win 10 64 |3X Nvidia Titan | i7 5820k | 32GB
dafassi
Hi im having renderproblems with an animation (particles).
I used a small glass-sphere to show particles and set meshtype to scatter.
The animation is okay till frame 144 - after that it seems that emitted light will no more seen in the glass-spheres.
Jumping to that error-frames and render a still frame will be okay.
Blend + ImageSeq are attached.
Greets,
Dennis
Reactor_Spheres_SEQ.rar
The image seq
(29.34 MiB) Downloaded 320 times
Reactor_Spheres_error.rar
Where the error begins
(3.76 MiB) Downloaded 317 times
ReactorSpheres_octane.blend
The original scenefile
(1.42 MiB) Downloaded 347 times
WIN7 64bit • 32GB DDR5 RAM • Intel i7 6x4GHz • GeForce GTX780 • Blender
kaiwas
Elonius, yes, but less noise for the same number of passes
voon
@Elonius
Appaqrently, with region render you're not suppsoed to look at Ms/s ... the image should still clear up faster than the entire rende, even if Ms/s are reported lower. i can't properly explain it, but that's what was said when region render became available.
Return to “Blender”
