Tried to reproduce this myself and cant.
If you want to know the exact version of Octane the plugin uses then open the log window. And yes, it is using 2.11.1. The main speed increases were to Direct Lighting and Path Tracing via a new Kernel pin called Coherent Mode. Do you really need the caustic calculations of PMC or would Path Tracing be good enough?SciFiFunk wrote:I'm not understanding if this release is using the latest Octane SDK 2.11.1 anyway or if I have to do something to get that before I apply your 2.11.0054 test.
I am having to use PMC on a particularly dark internal scene (no removing walls etc is possible (apart from a bit of one wall)), and it looks great but it's so slow. I understand the latest 2.11.1 has up to 30% speed increases so I want to make sure I'm getting that.
Having applied the 2.11.0054 test I'm not seeing a speed increase so I'm wondering what I've missed. Thanks.
p.s. I'm animating/rendering episode 10 and it's pretty stable. Some minor bugs but nothing that's impossible via a workaround.
Cheers
Yep, my bad. Will be fixed in the next update.dustrider wrote:Is anyone else having problems updating, or doing a full download of the LiveDB? I tried running the update and it crashed Carrara (and continues to crash) with 37 materials left. All I get is that useful message from Carrara "An error has occurred", clicking on either Cancel or OK results in Carrara crashing.
I tried downloading the entire DB to a new directory in case I had a corrupt file that was causing the problem, and that also crashed with 642 left to download. The text display on the ORVP also flashes quite a bit during download. I tried the last (previous) version of the plugin and experienced the same results.
This is with C8.5, Win7 Pro, downloading to the default location (\Documents\DAZ 3D\Carrara 8.5\My Presets\My Shaders\LiveDB).
