tried to add displacement to this model, but the render kept on failing, or freezing..
- anyway, slight SSS shading with marble and turbulence
manta ray bot
3dmax, zbrush, UE
//Behance profile //BOONAR
- LudovicRouy
- Contact:
Beware to use a low poly model before displacement ! and don't use a huge value, that will help ... good luck
yeah, but it shouldn't depend on polygon number.. a single poly can have a hiigh res displacement..
although I do have a shell on that mesh.. will try that with a retopo maybe
3dmax, zbrush, UE
Updates, in a SSS environment/volumetrics
..volume SSS material> schlick phase to 0.36, marble texture in scattering texture set to 0.2 (doesn't seem to show that much), scale 13 / IOR 0.99
the first image was on PMC 8 hours
2nd AO 20 min
2nd AO 20 min
3dmax, zbrush, UE
this one in DL AO, path term power 0, coherent mode.. 6 hours, ran it through nik tools and denoised
3dmax, zbrush, UE
