OctaneRender™ for Blender 2.06 - 6.0 Win [OBSOLETE]
aLeXXtoR
I've noticed that while rendering hair children Octane plugin uses the “Display” value instead of the “Render” value.
Win 10 Pro 64bit | GeForce RTX 2070 SUPER 8Gb | AMD Ryzen 7 3700X | 32GB RAM
WebSite
Showreel
mar
After instalation the Blender Octane version (Win 8.1) I got a prompt:
The program can't start because VCOMP12.DLL is missing ....
Any idea?
voon
Yes, Visual C library missing. Can be found at various places in this forum. Blender depends on it.
Elonius
MistAjuliax wrote:
JimStar wrote:
MistAjuliax wrote:Hair and fur can't be rendered,
Wrong. It can be rendered if you set the mesh type properly. Trying to use "global" mesh for heavyly scattered geometry is wrong way.;)
OK thanks it works. I was wrong, too excited, and too speed ^^. Nice to sse that we can assign a different material to parent object and hair and fur! How does it work? Does it render strands, or geometry type ??
Hmm. Could you please elaborate on how you got hair to work? I've tried everything I can think of. So how can I not use "global" mesh scatter?
mib2berlin
Hi, hair should work out of the box, Global or Scatter is more a setting to influence memory .
Cheers, mib
GTX 760 4 GB Driver: 430.31
Octane 3.08 Blender Octane
JimStar
Elonius
mib2berlin wrote:Hi, hair should work out of the box, Global or Scatter is more a setting to influence memory .
Cheers, mib
Awesome. Thanks mib.
pegot
Hm, when I render, it renders ... but I get no image .... viewport stays black....
.....FIX: Change the Distance value from camera.
This worked for me too, thanks! But is there a recommend number to set or will anything higher than the default 0 do without causing issues elsewhere?
Also, are we expected to change this setting every time we create a new file or is this a bug that will be fixed in a new release?
Win 10 - AMD Ryzen 9 5950X
MB: ASRock X570 Creator
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
MattRM
You are just awesome JimStar !!!
Matt
aLeXXtoR
2pegot Man, you can change any default setting in Blender (Ctrl+U etc.)
WebSite
Showreel
Return to “Blender”
