Version 2.10.0 - TEST1 - fixed (01.10.14)
lucioing
Ahmet the greatest! :D :D :D
L.
P. S. What about macos?
Mac Pro 5.1 -16 GB- 2 x Titan Black 6GB - Titan Z - MacOS Yosemite 10.10.4
mate
Very cool! Looks very promising!
Any chance our hairbug got fixed?
SEHSUCHT Berlin - 22x GTX 780
mate wrote:Very cool! Looks very promising!
hi mate, what's your bug? cannot fix the anythings without finishing the passes.
Method
Not working with R14?
ASUS P6X58D-E / Nvidia GeForce GTX 780 / 24GB Ram (DDR3) / i7 950 (OC4.2Ghz-without HT) / Windows 7 x64 / and million cooling fans :)
VFX/CGI, Animation for documentary movies, Music videos, Products renderings, Advertising....3D/2D (small production)
Method wrote:Not working with R14?
only R15 could be ready before weekend. I thought that one is better nothing. I'll try to prepare other versions
Method
Thank you very much! ;) looks great!
Ron
WOW - that was fast to update, Ahmed. Awesome job, thank you.
I did a first speed test on a current scene I am working on and got this results.
Still havy noise, but I will keep tweaking and see what I get.
With coherent mode:
OR2.10_Coherent_PT_1500_9.40min
Without coherent mode:
OR2.10_PT_1500_10,34min
Ron
Master: WIN 10 64bit, i7 4930 4,5 Ghz, 64 GB RAM, 1600 W PSU, 1 TB SSD, 14 TB RAID, 2 x RTX 3090
TonyBoy
Aoctar, I have C4D 12 and the plugin download for 2.06 includes C4D v12. Is this true or a simple mistake?
Sorry to jump in here but I had given up on the C4D Plugin.
Tony
Hi Ron,
thanks but how can you produce so many noises in a bright scene? Check my two render with 2.10. These are about 5min on 780+590, even with PT. For high emissions you should play with gi clamp. This will cut some emission rays. Accordingly will cut the fireflys. This will help to you for doing cleaner renders
miohn
Mike,
As i said that i can't change some layer buffers as ObjectID. So this is the main reason to develop new section and system for passes. But you may see correct output in saved images. Octane does colored objectIDs since beginning. Also many renderers does. Anyway we will add user controls to set colors.
Hi Ahmet,
no problem!
In saved image I have a colored version.
But whats then the difference between MatID and ObjectID?
One is then superfluous, or do I miss something?
regards
Mike
