iToo forest use causes CUDA 700 error
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
coilbook
Hi I thought my problem went away but now we use iToo forest park. Now constant cuda 700 error
1. We use only 3-4 trees 700,000 polys each and then clone it to hundreds. Can a lot of proxy objects slow down octane and make card work too much
2.also temp target and power target are at lowest 60% and it always freezes at the end not any where else.
PLEASE octane look into that issue and if it is hardware why does it away freeze at the end. Making animation is such a pain when it freezes after every 80-100 frames
3. it also says Device 0 does it mean one of the cards is bad. I got 4 in the box
Thank you
Karba
coilbook wrote:Hi I thought my problem went away but now we use iToo forest park. Now constant cuda 700 error
Thank you
Could you try to switch off the first device in octane render settings and try again?
coilbook
Thank you
Thanks Karba
Seems like if I disable the very top card 780TI in octane setting (Which is the bottom card in my netstor turbo box, that has 4 gtx 780TIs) it works more reliable.
Is my device 0 is the very top card in octane settings? I guess the card itself that happens to be device 0 is bad? Or once I disable the top one octane chooses another card as device 0 or nvidia decides?
Thank you
Karba
Thank you
Thanks Karba
Thank you
Can't say for sure regarding device numbers, but looks like there is some problem with one of your gpus.
coilbook
Strange thing that If I set the top card with Low Priority mode it works fine. But disabling priority mode gives me cuda error 700
Karba
coilbook wrote:Strange thing that If I set the top card with Low Priority mode it works fine. But disabling priority mode gives me cuda error 700
It is expected. The top card has some hardware problems and can't run at full load.
The device may be overheating, or doesn't have enough power or has some manufacture defects.
Return to “Bug Reports”
