weird triangle displacement
Moderator: JimStar
g0ll4m
does anyone know what might be going on here. When I add a displacement map, it displays weird triangulation artifacts.
Windows 10
Maya 2024.2
2 RTX 4090s 192 gb ram
itsallgoode9
is your geo subdivided enough to begin with? does this happen on all models or just this one? what happens when you apply the displacement to a simple plane?
g0ll4m
should I subdivide the geometry using smooth? or under the "extra attributes" using "octane:level". I will try using smooth and post an image.
Windows 10
Maya 2024.2
itsallgoode9
I use the octane smooth instead of maya's. make sure to switch the setting off global or the smooth effect won't work. It looks like that's your issue maybe.
g0ll4m
when you say octane smooth you're talking about "octane:Level" under the extra attributes? Also my mesh is set to reshapable proxy.
Windows 10
Maya 2024.2
itsallgoode9
yeah, that's what i mean.
g0ll4m
i've made a few examples.
Windows 10
Maya 2024.2
itsallgoode9
if you wanna upload your maya scene, with the displacement, i can take a look at it and see if i find anything weird going on.
g0ll4m
Ok, so this time I put the octane:level up to 4! It seemed to improve it a little bit. You can still see the tiny patches of distorted triangles.
I don't know what else to do to get rid of the black patches. I will upload my scene as well.
Windows 10
Maya 2024.2
g0ll4m
I think I finally fixed it. Last thing was Rayepsilon setting. Changed it to .0200
Windows 10
Maya 2024.2
Return to “Autodesk Maya”
