OctaneRender™ for Blender 2.06 - 6.0 Linux [OBSOLETE]
JimStar
The Linux version of OctaneRender™ for Blender plugin, 64-bit.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one..
  • Network rendering
  • Displacement mapping
  • Hair and Fur
  • Rounded Edges
  • Random Color texture
  • Improved Sky rendering
  • Region Rendering
  • OpenSubDiv support
  • A lot of minor improvements...
Installation:
- Just run the installer to see its command line keys.;)
- If you need to run the OctaneServer - run it as daemon:
# OctaneServer &
DOWNLOAD
Blender Octane Edition - v6.0 Linux (113MB autoinstaller file)
grimm
Oh yes! Awesome. Well that blows my evening out of the water. :D
Synthercat
OMG It's out! Must test it as soon as I get home.
Thank you Jimstar :)
Linux Mint 19.3 | GTX-1080Ti | AMD FX-8320 (OCed 4.4GHz) | 16GB RAM
kaiwas
crying for joy and waiting the correct activation :P
Synthercat
I upgraded to version 2 knowing I'd get ver2 plug for free... how do I claim my ver2 blender plug?
Thank you :)
grimm
Synthercat wrote:I upgraded to version 2 knowing I'd get ver2 plug for free... how do I claim my ver2 blender plug?
Thank you :)
You should definitely get in contact with [email protected], they should be able to help you.
Jim - I found a small bug. If you are working with the hair particle system and you enable the child particles it works great. Until you set the children display to zero so the view port is faster, then when you render in the viewport the particles do not get sent to OctaneServer. Even if you have set the children render number to a positive one. Once I reset the display number, the hair particles would render normally. At the least I would expect that if you set the display children to zero that the viewport render would just render the main particles, but in this case it doesn't render any of them.
Thanks again, I'm having way too much fun. :D
Jason
afecelis
Octane: Activation ERROR: This plugin account (xxxxxxxxx) is not valid for version 2.x.
Why God, why? :(
Win10 Pro | Geforce GTX1070 8gb Vram X2 (display/render) | Intel Core I7 4770K 3.5GHz | 32GB DDR3 1600 Ram |Nvidia 378.78 drivers | Cuda 8.0 | Blender/Modo/Sketchup
grimm
This might be a rather large bug. I can't render an image with either the render image button or F12. It goes through the motions but all I get is a black image. In the header message it says that it's doing a "combined pass - rendering". I don't have the render passes selected so it shouldn't be doing render passes, unless I'm reading the message incorrectly. So I thought that I might have messed something up so I reset all the settings to factory and then tried to render the default cube with an Octane material. Same outcome, no image, just black. Am I doing something wrong? Rendering in the viewport works fine, just the final render doesn't work. :(
Saramary
Grimm, have you ticked the Autofocus checkbox in camera settings?
Win 8.1 x64, i7-4930K 64GB, 2 x GTX-690
kaiwas
it is a bug?
[youtube]http://www.youtube.com/watch?v=g88Doaii0oY&feature=youtu.be[/youtube]
and... how to use hair and fur?
[youtube]http://www.youtube.com/watch?v=HsxSkwL0swo&feature=youtu.be[/youtube]
but thanks anyway! I'm happy
Return to “Blender”
