1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one..
- Network rendering
- Displacement mapping
- Hair and Fur
- Rounded Edges
- Random Color texture
- Improved Sky rendering
- Region Rendering
- OpenSubDiv support
- A lot of minor improvements...
Installation:
- Just run the installer to see its command line keys.
- If you need to run the OctaneServer - run it as daemon:
# OctaneServer &DOWNLOAD
Blender Octane Edition - v6.0 Linux (113MB autoinstaller file)
