Hair tips cut off
coilbook
MistAjuliax wrote:flyaway result
sorry i found an option in display to show more than 10,000 Thanks again
suvakas
Interesting. I didn't know it works like that.
Thanks a lot for the tip !
Suv
suvakas
coilbook wrote: Thanks Suvakas
So if I but a real hair plugin it will work with octane
It has been talked about.. search the forum and you should find some conversations about it. I think Ornatrix was supported?
Since I don't have any hair plugins, then I don't know how good the integration is. I do know, that plugins use Octane hair primitives instead of geometry.
Suv
MistAjuliax
Suv
De nada ;)
I forgot to notice that dynamics live works too. I will test some more and share results.
Regards.
Win 10 pro 64 / GTX 1070ti, gtx 1070 / FX8320E / 16Go DRR4
MistAjuliax
Another test ... i have to precise that primitive used is a cone primitive, and height segment has to be different from 1 otherwise it cannot be bend by parameters. Here heigth segment is set to 6.
hair and fur test
hair and fur test
HHbomb
hey guys, are you able to see hairs in octane viewport, or just in render window ?
In max 2015 I remember that I can see hairs in octane viewport, but not anymore... :(
suvakas
Hey Mist, how can you assign a separate material to teapot?
Mine always gets the same material as the instanced object has.
Suv
MistAjuliax
suvakas wrote:Hey Mist, how can you assign a separate material to teapot?
Suv
Hi Suv,
First i create a teapot and a primitive, here a cone. I assign a different material on each object, then pick up the cone in instance node and i open octane viewport. These are the steps i use, nothing else.
I specify that i use 3ds max 2015 extension 1.
2 materials
2 materials
coilbook
HHbomb wrote:hey guys, are you able to see hairs in octane viewport, or just in render window ?
only if i go to hair and fur effects and set type to geometry
HHbomb
arggghhh ! Hair and fur in geometry don't work.....
Return to “Autodesk 3Ds Max”
