Thank you for your awesome implementation of the node system.
It's so much easier now to understand the structure of textures and to build them.
It's a great improvement. Love it!
Regards - Ron
Last stabile version 2.06.1 - (09.09.14)
We have an issue with the hair rendering. Check the screenshots, scene is attached. Basically, the Octane Render will render faulty guides.
Here's the C4D standard renderer
Here's the same with Octane, the error very obvious
We tried the usual debugging approach of stripping the scene down to the minimal, which is attached. Error still shows up.
- SEHSUCHT_Hairbug_Testscene.7z
- (4.78 MiB) Downloaded 252 times
SEHSUCHT Berlin - 22x GTX 780
Hey mate,
where come from this output? LV or PV? Have you readed hair notes on manual?
@aoktar
It's picture viewer (final render), the hairs are generated at rendertime.
Of course we read the manual. Could you please look at the scenefile?
Thanks.
Thanks.
yes, checked. nothing looks strange. this is my outputmate wrote:@aoktar
Thanks.
Thanks for looking into it! Which cinema version are you using?
Maybe some other plugin? We'll look into it.
you're welcome. R15 and 2.06.1. Drop me a pm if you still have problemsmate wrote:Thanks for looking into it! Which cinema version are you using?
Hey Aoktar,
It's a bit hard to reproduce, but here's another scene with the bug. It appears on three different computers here if I just open the scene and press render.
::mate::
::mate::
- SEHSUCHT_v12_hairbug.zip
- (5.04 MiB) Downloaded 256 times
Also, please retry the first test scene a couple of times. The error still appears most of the times, just sometimes it doesn't. So I guess your quick test was just luck
