OctaneRender® for 3ds max® v2.06a (proxy support)
Karba
Main changes since version 2.06
  • Proxy support.
Main changes since version 2.05
  • Fixed high gpu memory consumption.
  • Fixed mix material viewport representation.
  • Fixed incorrect first animation frame
This is a test version, major bugs are possible.
DOWNLOAD
Installer http://render.otoy.com/plugindownloads/ ... _2_06a.zip (30MB ZIP File)
For network slave and daemon please download standalone installer here
http://render.otoy.com/forum/viewtopic.php?f=24&t=41635
Yours,
The OctaneRender® Team.
Karba
How to convert geometry to proxy
1) Select a geometry (one or several object), right click, Export to Octane Proxy
2) Set folder to store proxy files (file names will be the same as object names), replace original, and other parameters
3) Export
thilima
yeaaaah awesoome
WhaleHunter
Thanks Karba,
Awesome! We are downloading to test now.
About the Windows timeout / on big scene load times? Is this addressed yet?
Thanks.
Karba
WhaleHunter wrote:Thanks Karba,
Thanks.
No, it is not, unfortunately. I will try to fix time out next time.
What do you mean big scene load time? when you just open a scene file or start render?
bicket
thank you karba for this master piece of code.
it will help a lot
preview window is really fast
PortFolio
4 x TITAN - Win 7 64 - Octane Rocks
FamilyGuy
Stupid question but what does the proxy gives? What is the difference between proxy and instance? What are the benefits?
3dgeeks
Hi Karba,
Great work. We will be giving them a try.
In your opinion if we want to render animations with moving people, would it be faster and use less memory to use animated proxies or meshes with bipeds.?
WhaleHunter
When the scene is loading into the octane render buffer, the buffer can go not responding.
These scenes we cannot render interactively, or when the max scene is also open.
We have to send to backburner and render to a server.
Scene file opens in a reasonable time.
Still plenty of VRAM (6gb cards) and RAM (32gb on machine) remaining.
HHbomb
Waaahhhhh !!! Thank you very much Karba !! it is well worth the wait... :-)
Return to “Releases”
