Texture Transform
Many thanks, Ahmet.aoktar wrote:I have done a picture with some explanation. I hope that could be enough to explain process.
( PC ) i7 5960x octal 4.5ghz / 64GB / 2x Titan X 12GB / 1x 780 6GB - ( Laptop ) i7 4790k 4ghz / 32GB / 980M 8GB - Octane CD4 2.x / C4DR16.x / win 8.x
Hello Aoktar,
Unfortunately, it is impossible to texture so.
I have fit a company logo and the needs the right proportion.
In the current method, I can only guess if it fits on the scaling.
Would this proposal work:
I binder surface by mapping the texture in Cinema and create a second UVW Map.
The projection I assign Octane?
I hope can do something like this, because i need it necessarily
Greets,
NICK
Greets,
NICK
why imposible? No i don't think so. You can manually scale via transfor or projection scale. W/H -> goes to S.X.NVN wrote:Hello Aoktar,
Greets,
NICK
Even you can scale linked dummy with same way.
I could implemented that if your request is possible or easy
easiest way currently that creating a button like "Set ratio" or "keep ratio" in imagetexture or transform nodeNVN wrote:but for that I would need to know how big the scaling is at the beginning.
The texture is warped already at the beginning.
Plz, Aoktar implement it!!!! Its absolutely important if you have two diffrent Projections.
Plz Plz plz!!!!!![]()
your workflow can be impossible or hard to integrate current system. Can't say soo much now
sry aoktar, but the transform tool is totaly confused.
maybe it is a bug....i hope u can help me.
My texture was ok, but there are some strange errors?
- Transform.rar
- (3.56 MiB) Downloaded 216 times
