Hi.
Can i take with the texture transformation, texture projections of cinema?
Texture Transform
what are you meaning exactly? Cannot understand well...
if projection is UV in octane material and at material tag it's projection, it should work
no....
here is my example.
My Main Material needs a Cubic Prjection, because of the Noise Shader in my bumpmap channel.
My Cube2 (Octane) should look like cube 1 (Cinema 4d Materials)
here is my example.
- Attachments
- Projetion Mapping.zip
- (221.59 KiB) Downloaded 215 times
Rotate texture by "R.Z"
try Box or XYZ texture projections. Link a dummy object to manage texture to transform.
i can, start LV render and playNVN wrote:aoktar....i cant link anything in texture transform.
drag&drop wont work.
UVW Tags, Materials...nothing...
- Attachments
- Projection2.zip
- (171.62 KiB) Downloaded 215 times
Maybe a small tutorial for this if you have time, Ahmet?
I have always been confused how to setup a texture accurately like this also.
ten
ten
( PC ) i7 5960x octal 4.5ghz / 64GB / 2x Titan X 12GB / 1x 780 6GB - ( Laptop ) i7 4790k 4ghz / 32GB / 980M 8GB - Octane CD4 2.x / C4DR16.x / win 8.x
