3x riser
resmas
acc24ex wrote:In my case - non powered riser worked on a 580... but none of the 590 gtx
- I got 3 590s and powered risers work great.
- maybe a single 590 might work, but it never did in my case - and mainly the only "bug" was, that my system didnt recognize the GPU - it was mentioned in several posts that you are way better off using powered risers - so people, at least browse for keywords, you just might get a better response
Hello mate, just another question, your powered risers are those USB tipe, or the 1x to 16x?
Thanks for your time.
cheers
resmas
i7-2600k | SSD Vertex 3 | WD Velociraptor | WS Revolution | 16GB Ram HyperX | PSU LEPA G1600W | 3 X Asus GTX590 |
https://pt-pt.facebook.com/arq.resmas
slepy8
my one are 1X
with 60cm USB cable. It gives lots of freedom in building the rig.
Daniel79
2x riser work!!
I have 2 gtx 580, 1 gtx 570, 1 gtx 660 ti, and the riser work perfect whit all vga
Bye bye
SORRY, MY ENGLISH IS BAD!
2 Xeon quad core E5440_8gb Ram_Nvidia GeForce 2GTX 780ti 3Gb/Nvidia Quadro K2000_Win10 64bit_Octane 3.02_Rhinoceros3D
Seekerfinder
Daniel79 wrote:2x riser work!!
Bye bye
Hi Daniel,
You using x16 to x16 risers? Which ones?
Seeker
Daniel79
Yes i have used x16 To x16 whitout no powered...
Seekerfinder
Daniel79 wrote:Yes i have used x16 To x16 whitout no powered...
Ok, thanks Daniel. That means either that the MB power is carried thru those risers or that your cards have not had the need for too much power yet.
Best,
Seeker
