This is the recommended thread for downloading, and posting any questions, suggestions or support queries for OctaneRender for Carrara 2.0 - BETA RELEASE.
Carrara Version
This version requires Carrara 8/8.5. This version runs on 64 or 32 bit Windows 7, 8, and 8.1. The .NET 4.5 Framework is required.
- Operating System (ie. Win 7, 8, 8.1)
- 32 or 64 bit
- Amount of RAM
- Nvidia driver version
- Carrara version
- OctaneRender for Carrara version (ie. 2.06.0047)
- List what other plugins you have installed for Carrara
- The most important part of resolving a problem is me being able to re-produce that problem. So pls provide as much detail as possible in order for me to do this, and if the problem is specific to the scene, send me the scene.
Change Log
- For the Change Log see here.
Known Issues
- Carrara can crash when consolidating materials. (Edit->Remove Unused Masters->Consolidate Duplicate Shaders) The exact cause of this issue is still unknown as there is no reliable repeat case and I have not, myself, been able to reproduce this issue. If you can find a repeat case then I will reward you with great praise. It is highly recommended that you save you scene and close the ORVP before trying to consolidate.
For more information...
- Read the on-line manual.
- Post your question on this forum thread
Purchase page is here.
Download Links:
OctaneRender for Carrara (64-bit) 2.06.0050
OctaneRender for Carrara (32-bit) 2.06.0050
Demo Versions:
OctaneRender for Carrara (64-bit) 2.06.0050 Demo
OctaneRender for Carrara (32-bit) 2.06.0050 Demo
Happy rendering!
OctaneRender for Carrara 2.06.0050 [Stable]
Thanks for the update
Ah great! Well done.
I only noticed this just now as I'm about to report the animation sticking on the same frame issue again. You wanted diagnostics. Note this is from v0048 then, but it might be useful info..
(sorry not sure how to open diagnostics, just have log here. Doesn't look that useful but included anyway.) Now cleared down. First time I'd looked at the log.
LOG.
[09:37:58.869] OctaneSceneManager::RenderWindowClosed
[09:37:58.869] OctaneSceneManager::UnloadScene(000000002BF2207C)
[09:38:01.755] >>>>>>>> OctaneShader::GetTextureMultiplyColor <<<<<<<<
[09:38:01.770] >>>>>>>> OctaneShader::GetTextureMultiplyColor <<<<<<<<
[09:38:06.419] OctaneSceneManager::RenderWindowOpened()
[09:38:18.572] >>>>>>>> OctaneShader::GetTextureMultiplyColor <<<<<<<<
[09:38:36.637] >>>>>>>> OctaneShader::GetTextureMultiplyColor <<<<<<<<
[09:38:37.432] >>>>>>>> OctaneShader::GetTextureMultiplyColor <<<<<<<<
[09:38:38.446] >>>>>>>> OctaneShader::GetTextureMultiplyColor <<<<<<<<
[09:38:39.476] >>>>>>>> OctaneShader::GetTextureMultiplyColor <<<<<<<<
[09:38:40.505] >>>>>>>> OctaneShader::GetTextureMultiplyColor <<<<<<<<
[09:38:41.535] >>>>>>>> OctaneShader::GetTextureMultiplyColor <<<<<<<<
[09:38:42.565] >>>>>>>> OctaneShader::GetTextureMultiplyColor <<<<<<<<
[09:38:43.594] >>>>>>>> OctaneShader::GetTextureMultiplyColor <<<<<<<<
[09:38:44.639] >>>>>>>> OctaneShader::GetTextureMultiplyColor <<<<<<<<
[09:38:45.653] >>>>>>>> OctaneShader::GetTextureMultiplyColor <<<<<<<<
[09:38:46.699] >>>>>>>> OctaneShader::GetTextureMultiplyColor <<<<<<<<
[09:38:47.713] >>>>>>>> OctaneShader::GetTextureMultiplyColor <<<<<<<<
[09:38:48.727] >>>>>>>> OctaneShader::GetTextureMultiplyColor <<<<<<<<
[09:38:49.772] >>>>>>>> OctaneShader::GetTextureMultiplyColor <<<<<<<<
[09:38:50.786] >>>>>>>> OctaneShader::GetTextureMultiplyColor <<<<<<<<
LOG.
0049.
CTRL-SHIFT-O still renders for me, not CTRL-SHIFT-R. Doesn't matter as I've remapped my keys, (although a good fix for new people). I'm in 8.1 Is this an 8.5 thing only? I confirm I copied the files over.
Also I tried to see which version I am in the program. Log doesn't go to that level. I'm checking atm by comparing the last modified date in the 8.5 folder vs the 8.1 folder. They are the same.
Try opening the RenderTarget settings. If there is a reset button then you are running 0049.SciFiFunk wrote:0049.
Maybe it is because you remapped the keys that the change cannot be seen?
Win8/64, I7-4770K (3.5Ghz) 24GB, GTX-980ti (6GB) / GTX-TITAN (6GB)
From the log I don't see the new diagnostics I added. (The log is the diagnostics I was talking about). I don't think you are running the latest version. I'll get rid of that annoyance message in the next build.
When you run the installer do you change the install path to point to your 8.1 Carrara directory?
Yes it is still ok to copy the file but the installer should be working now.SciFiFunk wrote:Hi,
I didn't think that was working (changing the directory). Instead I am extracting into the 8.5 directory and then copying the whole folder to my 8.1 installation.
Is this ok?
[EDIT] I confirm I see a Reset button.
4 tests in with the reset button and no issues.
These are all simple camera move only animations, but still it is a good test of the stuck frame issue, which also has not re-occurred.
I'm still working on the larger model, which I think will be a good grouping of objects/ multiple objects test. Some CTRL-D duplication is involved, but not enough to test Octanes limits.
For simple animations and Octane material manipulation it's feeling pretty solid and reliable now. Great progress.
I've no idea how complex the single material CTRL-D instancing is, but I'd love to put Octane though it's paces with some of my massive scenes. The Ennis house video should be a good advert for the plug in for example.
