Version 2.05.0 - Updated on (14.08.14)
ASyme1
cyartist wrote:Now after thinking about it I remember it was something to do with some Splines I had in the scene as I got a duplicate naming error warning on the splines.
Once I deleted the problem Spline the file rendered fine. Do you have Splines in your scenes or duplicate same named objects?
Hi Cyartist, we'll yes there is a spline in the scene. I'm driving the main render camera along a spline. Not sure why I would get a duplicate naming error though. Odd that it doesn't work in 2.0.5 but does in 2.0.4.
Alec
Alec Syme
http://www.fuseanimation.com
-Gigabyte X79-UP4 - Intel i7 3930 3.4 - Windows 8.1 Pro 64bit - EVGA TITAN X7 - 32 Gigs Corsair 1600 4 channel RAM -
cyartist
I had a bunch of Splines with the same name..that was the issue according to the error window.
Once I deleted the splines the file rendered fine even after i replace them with new splines.
If you have a large scene maybe see if some items are names the same and rename them or remove them to see if it helps. Again just a suggestion maybe something else in your case.
alec, do you have motion blur? it can cause issues
artdude12
There was a crash warning about using Nvidia Driver 340.xx (My current is 340.52) posted on CG Talk by Srek on behalf of Maxon saying they have reproduced a crash caused by this driver. Is this an Octane concern as well? Personally, I haven't had the crash he is referring too. Here's the link: http://forums.cgsociety.org/showthread. ... &t=1215144
i7 4930K_Asus_RampageIV-Extreme_64GB_3-Titan_NVIDIA-337.88_Win7-64
cbmotion
Hi Ahmet -
The 2.05 work nearly perfect for me on mac and r15
only the tiger example from you - the fur didnt get the root color from the texture
cheers
carsten
ASyme1
aoktar wrote:alec, do you have motion blur? it can cause issues
No, I gave up on motion blur with this project. It's too big. It may just be too big for the GPU's.
alec
Alec Syme
Hi guys,
That's a new feature, i'm working on. I think that will makes some sense on someone. Soon i'm going to release 2.06 with some bug fixes/improvements. Also it's possible to add nodes as a preview version.
aoktar wrote:Hi guys,
Wonderful Ahmet, the node graph will drastically improve the c4d-octane workflow, bravisimo :D
ciao beppe
cfrank78
I am playing at the moment with the WIP of the node editor. Guys look forward this baby is MIGHTY and sooo much fun wuuaaahahaha. Combined with the ctrl/alt LMB, MMB and RMB workflow in the live viewer, this is now simply the best workflow ive ever had in any render engine. awesome!
Good JOOOBB Ahmet - get it Done :-)
ten
Wow, this looks great :-)
ten
( PC ) i7 5960x octal 4.5ghz / 64GB / 2x Titan X 12GB / 1x 780 6GB - ( Laptop ) i7 4790k 4ghz / 32GB / 980M 8GB - Octane CD4 2.x / C4DR16.x / win 8.x
