Problem with Displacement
centropolis
Hello,
hi, I purchased and installed the version 2.06 of octane render standalone and plug-ins for cinema 4d version 2.03. everything works ... but on displacemnt I have problems.
in the viewport render nothing is changed despite changing the displacement. load an image. I dunno. do you have any tutorial to follow. maybe there is some setting that I do not understand you ..
Suggestions?
Many many thanks.
Centropolis
Intel Core i7 / 16 Gb Ram / 2x GeForce GTX680 1536+1536 Cuda Core / Windows 7 Pro
Hi, exactly didn't understand what are you doing. But first install standalone 2.05 and plugin 2.05. This is best for displacement.
No need any tutorials. Only use Octane materials for displacements. Use first a displacement node, and place a image to this. And activate displacement from material manager. Two images and a sample scene are below. That's all
Keep enjoy
displacement1.zip
(148.6 KiB) Downloaded 288 times
Rudi
Hello,
what I make then wrong because I still these stairs see with the Displacement . :(
Greetings Rudi
your are still expecting magic via a low res image. Check my picture, displacement source image which is produced by a gradient
Rudi
Hi aoktar.
This is your upload : http://render.otoy.com/forum/download/file.php?id=35484
I load this in C4D and render it.
Therefore, my question whether with me what is wrong put. :(
inlifethrill
Rudi wrote:Hi aoktar.
The uploaded file works as epxected. What is the question?
Rudi
The question is, what am I doing wrong probably because this file is created stairs at me. so long the thread is not that you have to ask.
@aoktar,
can you please give a finished Displacement material times, so that I can understand with the gradient and everything else to me.
prodviz
Do you guys have procedural displacement in Cinema 4D?
cheers.
prodviz wrote:Do you guys have procedural displacement in Cinema 4D?
cheers.
plugin automatically can convert any shaders to imagetexture. So this is possible with this way
prodviz
That's really cool.
So does the conversion to image file happen on the fly, as you're using the IPR?
I'm on the Maya side, so we don't have this option.
