Color picker position not saving
formatio
Hi
I found that color picker is in default position somewhere on the left top (more or less).
When I move it so it is closer to my materials panel, close it by clicking "ok" (chose color or not, doesn't matter), next time I open it it's not in the previous place (that I moved it to) but in new position, and even different position than default.
Would be nice if the position of color picker could be saved (during the session) :D.
Also couple of times rhino and the plugin crashed - always when I was meddling with color picker (I am not sure, but it might be when I slide sliders too fast - I'll investigate it further to give better feedback on this)
Regards,
Mac
Hi Mac
Done in the next release (saves the position to the config.xml file, so persists between session.
I've had 2 or 3 crash reports from that Color Chooser dialog fro McNeel. I posted fixes for these in 2.5.2.11. Are you using that version? If you get any crash - pls send me the crash report.
formatio
Hi Paul,
Yes, it appears that I am using 2.5.2.11, only octane plugin installed.
I'll catch crash dump next time Rhino crashes and post here. (Crash happened only two times so far :) )
Regards,
Mac
Return to “Rhinoceros 3D”
