OctaneRender 2 for Poser (Windows/OSX) [OBSOLETE]
Andygraph3D
ok now i need fix the problem about the message:
"This pz3 file was saved with prior version of OctaneRender for Poser, and save of the saved setting may not be compatible with the current plugin version."
Is there a way for delete/reset the poser octane plugin setting ?
I suspect your startup scene has old Octane info saved in it. I suggest Zays suggest:
In preferences, try clicking on the button Set Preferred Scene as the old scene might be the problem that triggers the message.
If that does not work....does the message appear when you open the plugin with the default Andy scene? If so, can you pls send me a copy of your octaneplugin.log file after loading the default Andy scene and then opening the plugin (where the warning pops).
Andygraph3D
The message appear when you open poser in startup on a empty scene and no when open the plugin.
Suggest you try Zay's fix above. If that doesn't work, pls send me a copy of your startup scene.
Andygraph3D
how i can send you the startup scene ? I open only poser application.
I need open poser save the scene and send it to you ?
Open Poser, File Save As, zip up the resulting pz3 and post it here pls. Also send me the octaneplugin.log file I requested a few messages above.
Andygraph3D
This are the files.
another problem error now when open Octane Render Viewport
"Can't load image saveButton.png: the file does not exit"
poser10 startup.zip
(12.94 KiB) Downloaded 302 times
Hi Andygraph3D
Your Poser startup scene contains Octane plugin data - so you need to do as Zay suggested. Edit->General Preferences->Launch to Factory Scene. Your startup scene has Octane 1.5 data saved to it - which is triggering the warning message.
I have updated the 32 bit installer to fix this issue - so you can download and re-install to correct this message.
Andygraph3D
fixed thx Paul and Zay ;-)
i have see other messages error about displacement map .. wrote here soon
RGUS
Just a little grammar thingy... or maybe it's just my Kiwi English... but should the "as" be an "a"..???
Anybody know how to fix this by the way?
RAM: 64GB
OCTANE PLUGIN VERSION: 2025.6.0.4.09 Prime BETA
DAZ STUDIO VERSION: 4.24 Pro Edition (64 bit)
Return to “Poser”
