need material shader organic skin
standard mix shader of complete nonsense
SSS skin material
- Elvissuperstar007
- Contact:
- IMPICHMENT
+1
I, too, for this idea. We need to think how to simplify workflow Octane to make it more accessible to artists.
Cinema4D R14.|Octane Stand | Octane for C4D next Corona render
Win8 [64]. I7 3930K . GTX580
- gordonrobb
I'm not sure what you're showing here as you haven't shown the octane one on a model. I've used TonySculptors material to great effect, and all just by sticking the appropriate image in the appropriate node (and that was having converted them for Lightwave). The other apps materials look just as complicated or difficult to understand.
- gordonrobb
Plus, you're in danger of criticising Tony's generously donated material, rather than being specific with OTOY as to what you want.
Human skin is one of the most complicated materials to reproduce, because of the things You need to keep in mind while setupping it.
Octane render has more or less standart map slots & You can get very good results with it
(free material that Gordon mentioned from TonySculptor is a good example to iliustrate that).
What You need is a bit more work, rather than talking that shader is too complex..
If OTOY is going to make shader more simple, other users will start talking that it's not flexible enough..- it's a closed loop..
Some of the best artist around (like Bertrand Benoit) put up very complex materials (shaders are simple enough,
but the amount of maps, tailor made for specific object are insanelly detailed) - there's no shortcut to reach quality..
Huh? Maybe switch to the input pins???Elvissuperstar007 wrote:need material shader organic skin
- gordonrobb
Totally agree with you. I mentioned TonySculptors excellent material as that is the one that was shown by the OP with a 'WTF' beside itglimpse wrote:Human skin is one of the most complicated materials to reproduce, because of the things You need to keep in mind while setupping it.
- Elvissuperstar007
- Contact:
I did not mean bad shadergordonrobb wrote:I'm not sure what you're showing here as you haven't shown the octane one on a model. I've used TonySculptors material to great effect, and all just by sticking the appropriate image in the appropriate node (and that was having converted them for Lightwave). The other apps materials look just as complicated or difficult to understand.
- Elvissuperstar007
- Contact:
a lot of unnecessary body movements while creating materialabstrax wrote:Huh? Maybe switch to the input pins???Elvissuperstar007 wrote:need material shader organic skin
it is necessary to spend a lot of time on the move to and fro
sorry for bad english
