OctaneRender® for 3ds max® v2.04
rodrigotrovao
should have a switch to or turn to geometry as you choose octane for rendering..
mikinik
Karba, thank you! GI Clamp works perfectly!
r9 3900x/64Gb/2070s/2070/win10x64/3dsmax2021
acc24ex
not sure if it's my max, but on v 2015, I got max crash second time while applying a uvw map modifier, on a moveable proxy object while the render was live on preview window / also the project was opened from a v2014 file
coilbook
i thought it would not but it did .. rendered well for 400 frames.Then I Stopped it.. after paling the game , browsing.. it rendered 30 frames and then it stopped with 700 error. it is very hard to do an animation
coilbook
I relaunched the scene and it did it after 4 frames. So if i did not interrupt it it would've finished all 800 frames; but after playing the game, browsing, using sony Vegas Octane freezes.... wonder what messes it up
coilbook
bug report in case other forums are not for that Still freezes frame 0 is dark , sometimes it goes 300 frames, sometimes 2. I doubt it is PSU or temperature
Karba
coilbook wrote:I relaunched the scene and it did it after 4 frames. So if i did not interrupt it it would've finished all 800 frames; but after playing the game, browsing, using sony Vegas Octane freezes.... wonder what messes it up
I am pretty sure it is a hardware issue.
Rico_uk
I would be dissapointed if it is a hardware issue, I've just bought some new cards, big PSU, motherboard, etc. If my setup isn't good enough then I don't know what system could run Octane with multiple cards.
I have the same issue, black first frame, renders freeze towards the end of a random frame in a sequence.
gabrielefx
Hi Karba,
you checked my scene "mylights"?
If I open the scene contained in the zip archive, that I've created for the community, and I hit "open the OctaneRender viewport" button, nothing happens.
If I hit the Render button the render starts.
Octane 2.04, Max 2014 latest update, latest drivers, etc., etc.
If I switch "on" the first ies while the Octane render buffer shows that gradient shape the render starts.
Please call these releases beta or put the daily builds in a private ftp where I (we) can have access.
Thank you.
coilbook
thanks Karba
Return to “Autodesk 3Ds Max”
