Network Rendering
kavorka
It seems to be that when using network rendering, if one of the slaves disconnects, you lose all the samples from that computer. Is that right? is it a bug or something that is known?
abstrax
kavorka wrote:It seems to be that when using network rendering, if one of the slaves disconnects, you lose all the samples from that computer. Is that right? is it a bug or something that is known?
A slave is treated the same way local GPUs are treated. Which means you will lose all samples when a slave is disconnected. It's a limitation which we hope to solve at some point, but it's a bit trickier than it sounds.
