2.02 - 4.0 - Camera Problems
Moderator: JimStar
sirenesoong
I have problems with 2.02 plug-in with camera:
please, see this image:
I used octane camera, and I have the same problem even if I open scenes made by 1.55 plugin.
Thanks for help
Q6600, 8 GB ram, Geforce480
luk4
I have the same problem...
L.
4x Titan Black | 4x Gtx 780 6Gb | Gtx 470
JimStar
Can you give me this scene please?..
sirenesoong
of course. This is the scene in Maya 2015:
http://www.mosaica.eu/camera_Error.rar
thanks!
TBFX
Yes same issue here
T.
Win10 x64|i7-9750H 2.6 GHz|32 GB RAM | RTX2080 max Q 8GB
ciboulot
It looks like you have the "resolution gate" problem.
I had this problem many times. When you set your setting to anything else than "fill", octane does not match the settings.
I've tried evry settings, the only one that works is "resolution gate : fill".
But maybe it is something else.
Laptop HP 8760w, I7, 16Go ram, Quadro fx3000m, Maya 2014, Octane 1.20a. Vimeo: http://vimeo.com/ciboulot/albums
JimStar
It is already fixed.
p3taoctane
I just installed 2.02-4.1 and have same Camera issue not rendering what is in modeling viewport.
After installing the 4.1 version my saved bookmark is not longer what it used to be. I am zoomed the the hell in.
I did not have this issue in 2.02-4.0
Peter
JimStar
p3taoctane
This was reworked to more properly reflect the resolution gate of rendered image in Octane. Just enable the "Resolution gate" mode in viewport camera settings and you will see the exact fit.
p3taoctane
Not sure if I agree Jim Star.
If you are talking about the Display options in the perspDhape node.
Display Film Gate
Display Resolution
Display Gate Mask
Overscan etc.
That should not change your view if the Device Aspect Ratio set in the Image size by your width and Height match your film aspect ratio
In my case both 1.778
Adding the Gate and resolution should not cause a jump in view. It will just show you what your res gate is and what is outside it etc.
Or are you talking about something else I am not aware of.
Peter
Return to “Autodesk Maya”
