Computer crashing with octane.
MaTtY631990
I have not a bad problem before like this.computer is crashing a lot when using octane viewport. Anyone get this problem. It's strange considering, I rendered out an animation that was going a few hours and not once crashed. Useless.
Karba
MaTtY631990 wrote:I have not a bad problem before like this.computer is crashing a lot when using octane viewport. Anyone get this problem. It's strange considering, I rendered out an animation that was going a few hours and not once crashed. Useless.
Do you use displacement?
MaTtY631990
No displacement.
nagboy
Be careful that no other application that is using GPU acceleration is running. For me this a source of trouble and crashes.
MaTtY631990
No other application running, is just 3dsmax and octane. Does it have any impact from the way scenes are designed? I ask because I just rendered for 40 minutes a teapot and plane object with full glossy materials in Pathtracing at 10000 samples and not once crashed. Now the scene I am specifically talking about is a bedroom and kitchen, but the problem is a lot of the meshes such as cupboards/drawers are not closed and may have open verts, double edges etc. Simply put a bit of mess close up. Can this cause problems for renderer. It simply runs in octane viewport for a couple of minutes in Pathtracing and the computer loses signal, then freeze, then crash.
MaTtY631990
It works fine with simple scene but as soon as I render interior, it crashes after say 5 minutes.
Return to “Autodesk 3Ds Max”
