Karba asked you do you have some other program running parallel with 3dsmax that could steal memory from graphic cards. Maybe your renders failed because of lack of free memory on graphic cards.vfxman83 wrote:What do you mean parallel ? two card installed on the main board
1.gtx
empty
2.gtx
i installed llike this.
OctaneRender® for 3ds max® v2.02
- mark0spasic
AMD FX 6300, 24 GB RAM, Gigabyte ga-990fxa-ud5, 2x MSI GTX 780 3GB
Hi vfxman83,
I have had this problem a lot of times. That's because you have too much geometry in your scene, at least more than 1.97Gb (your card limit).
I suggest you to use movable proxyes for vegetation and to use layers for reducing geometry.
But although if you don't do this, Octane can render this scene as it is (with a little trick):
1- Restart your computer and open the scene
2- Hide the highpoly elements (or layers)
3- Start Octane render viewport and when it starts rendering pause it (if you have less than your card limit of geometry it will start rendering)
4- Unhide what you have hidden before
5- Resume renderer and "update render geometry" (it will say RENDER IS FAILED again and again, but it will render)
Hope it helps
Hope it helps
You are running out of memory. You have only 1.9 gb available for Octane. The scene you have seems quite large.vfxman83 wrote:Karba I used only 3ds max program when I was rendering and I used Asus gpu tweak software for oc.
Probably Max viewport takes some of your mem and not enough left for Octane.
Suv
Hi, Karba! I do not know if sombody already reported this, but I've found this bug. Below are the renders of the same mesh with the same smoothing done under MAX 2014 Octane 2.02 preview and then imported as Alembic in Standalone 2.02. Defenitely something wrong in the Standalone picture, since the smooth is rough compare to MAX preview render. So, is it a bug or?
Update: It is working correct in OctaneRender for 3ds max® v2.01
hi karba
we got some strange issues with the frame buffer in higher resolutions: the clone to framebuffer worked, the image also looked like it had to.
win8.1
nvidia driver 335.23
one gtx used for display, all other gtx 680 rendering, no memory overflow (all have 4 gb)
win8.1
P6T7 WS SuperComputer / i7 980 @ 3.33GHz / 24 GB / 1500W + 1200W PSUs / 6x GTX 680 4 GB + 1x Tesla M2070 6GB (placeholder
no offense but you can't blame otoy or karba for failing client delivery. it's your software choice and your job to calculate the risk of using it in your production pipeline.criko3d wrote:Karba, am just making an open complain as a customer and am tired of working with a software i paid for rendering not for bug hunting, so hold your horses... I have the right to complain if i buy something that doesnt work properly as it was offered. Please feel free to delete this post i dont care anyway, am done with this. (Btw i just failed on client delivery for the freaking bugs) Thanks!
