Version 2.05.0 - Updated on (14.08.14)
Rudi
Hi aoktar
In the Displament channel the invert can't function. The image does not change.
Greetings Rudi
Rudi wrote:Hi aoktar
Greetings Rudi
yes, it's limitation of renderer. Only works imagetexture and tranforms
Rudi
In other words, it stays that way and you can do nothing at all? :(
Rudi wrote:In other words, it stays that way and you can do nothing at all? :(
correct, we should expect some fixes on Octane core
Rudi
Ah... :) So there is hope :)
Rudi
Hallo Aoktar,
i have a Renderfailur
octane 2.02 140705 175953.log
(27.52 KiB) Downloaded 229 times
Weezer
You can always just invert the image in Photoshop...
Rudi
Thx... nice Idea :) First as a transition.
cgdept
please HELP!
Hi !
1 install octane 2.02 if 2.00 for cinema4d plugin (older version octane good worked)
2 start programm
3 CRASH CINEMA4D
help!!!! aaaaaaa)))!!!
my videocards
primary quadro 6000k
and 3x nvidia 780ti
drivers qudro - fresh
Tnx!
shawnfrueh
Network rendering is really random when it wants to work. Here is a screen shot of the devices in standalone and what octane is seeing:
Now what I had to do to get this to work, (For those of you who are having the same issues,) was to then turn off the standalone and then turn it back of so that the devices disappeared. Now you can go into the octane network preferences and check the devices you want to use.
My guess is that the plugin is conflicting with the standalone settings? Hopefully this can help Aoktar to make this process more streamlined.
A neat trick I had been shown to "unfreeze" the network settings when opened from Cinema is to click on the cinema icon on your task manager and makes the window unfreeze.
