I have discovered another problem with motion blur. When Vertex motion blur is enabled I sometimes get black polys. When I turn off Vertex and change it to Transform The issue is fixed.
Vertex on:
Transform On:
Version 2.05.0 - Updated on (14.08.14)
pls could you post your scene, for checking the issue?shawnfrueh wrote:I have discovered another problem with motion blur. When Vertex motion blur is enabled I sometimes get black polys. When I turn off Vertex and change it to Transform The issue is fixed.
Vertex on: Transform On:
Aoktar, awesome work on the 2.02 plug in, the advancements in the plug-in are amazing! Just wondering if there is any difference in using the Foreground and Background object in the live viewer. It was working in 1.5.2 and have been using it for compositing work very successfully. Can you check this, or anyone else confirm it's not working? Thanks again, awesome job!
Win 10, Threadripper Pro, Dual 3090s
Thanks i'm trying to make it better,LFedit wrote:Aoktar, awesome work on the 2.02 plug in, the advancements in the plug-in are amazing! Just wondering if there is any difference in using the Foreground and Background object in the live viewer. It was working in 1.5.2 and have been using it for compositing work very successfully. Can you check this, or anyone else confirm it's not working? Thanks again, awesome job!
i have worked on back/fore. objects since 1.52. It should work on LV and picture viewer as usual with standart material. Standart material should have a image in diffuse channel.
hi,tkkim wrote:Hi, all!
Please help me.
How can I make slave machine with my mac(GTX580) in network rendering.
There is no _install_daemon.bat file in mac version.
the net rendering is managed by the standalone version. infact you don't need a separate plug-in licence for the slave but only a standalone licence.
In the osx standalone 2.02 installer you can find the install_demon and uninstall_demon scripts
ciao beppe
bepeg4d wrote:hi,tkkim wrote:Hi, all!
Please help me.
ciao beppe
Thank you so much!!!
I will try!
in 2.02 as motion blur in enabled in the camera-tag, the blur is globally always activated. no matter which settings are used in octane object tag or octane render settings.
plus: the images seem identical in lifeviewer/pictureviewer, but upon saving the png from pictureviever is significantly darker.
c4d win r15
file IS attached
br.
mo
c4d win r15
file IS attached
br.
mo
- MB_test.zip
- c4d-file
- (70.61 KiB) Downloaded 184 times
tkkim wrote:bepeg4d wrote:hi,tkkim wrote:Hi, all!
Please help me.
ciao beppe
Thank you so much!!!![]()
I will try!
Hi, bepeg4d
If I make slave machine, I have to buy another standalone account?
hi,tkkim wrote:[Hi, bepeg4d
unfortunately yes, for now.
Otoy has already said that in the future the net licence scheme will be changed, probably with a properly slave version, but we don't know when will be
ciao beppe
