bug animation mode camera only
Moderator: JimStar
olivierj
Hi, when i render in this mode the renderer skip evaluating some frames, i have to go back to version 1.2 to get it working and render properly all the frames of the animation. Any ideas ?
JimStar
Are the skipped frames always the same?
Can you please give me the scene where you have this issue (with annotation about what frame-numbers are skipped in your case)?
olivierj
Hi jim, it doesn't actually skip frames but instead render one and save it many times like if it did render the next ones, then jump to render another frame that it will save many times. The amount of time it will save a frame seems random.
Here is a scene and a render. that problem doesn't happen with V1.2
cheers
P2_debug2.rar
(2.41 MiB) Downloaded 183 times
TBFX
This issue is also present in the movable proxy mode. It seems full animation mode is the only one that works in batch render at the moment.
T.
Win10 x64|i7-9750H 2.6 GHz|32 GB RAM | RTX2080 max Q 8GB
Return to “Autodesk Maya”
