This is a issue Renderer's. I'm sure development team is aware of this. As understand, they are trying to keep interactivity. This causes some problems on some features. We hope that may be better, thanks enjoy it.Raoul wrote:Hey Aoktar,
I'm really enjoying the latest build! Displacement maps have been extremely useful.
The one feature i had some queries about was the edge round option.
I've found it to be extremely useful in vray4c4d but the way it seems to be implemented in octane c4d doesn't seem quite right.
I find that the bevels get stretched based on the polygon size its applied to. Whereas vray keeps a consistent bevel size regardless of geo.
Is this something that you might be able to look at? or is it more to do with the octane core, (not the cinema adaptation).
Any info or future plans on this would be super good to know as its a simple but very very useful feature.
Thanks again for your hard work on the plug.
R
Version 2.05.0 - Updated on (14.08.14)
1. I've updated it to 2.0.1 Standalone. Will try to disable that but is that the reason for c4d to not be able to distribute the render to the Pc (Slaves)? They were just working for LV.1. possibly, you need to update to latest standalone 2.01. Also macosx energy saving function makes the render daemon is sleeping.
So pls disable this from info window of octane_slave or octane_daemon application.
2. I don't aware this. You should not need for baking except objects which has dynamic simulation.
3. yes, expensive. Two option will help. Power and sampling of emissions. Optimisation is a work of Octane team. We hope that.
4. need some sample to check it. There is a different behaviour on objects which have objecttag.
2. Camera inside an align to spline i guess is also not providing coordinates for motion blur to grab onto. These two images show the result when switching from a baked align to spline from a live one. Not sure it warrants a fix more so than an fyi for any spline paths camera moves.
3. Got it.
4. Ok I'll have to test some more. Thanks.
Hey Ron,Sorry - I am a bit confused. What is the latest build of the plugin?
I am using 2.00.24 at the moment.
Regards - Ron
I believe I'm using the latest version (on the first page of this thread) 2.01 (it uses the latest sdk) for both mac and pc.
Thank you - will update now.MINGATU wrote:Hey Ron,Sorry - I am a bit confused. What is the latest build of the plugin?
Regards - Ron
Master: WIN 10 64bit, i7 4930 4,5 Ghz, 64 GB RAM, 1600 W PSU, 1 TB SSD, 14 TB RAID, 2 x RTX 3090
- indexofrefraction
hi aoktar,
about speed in 2.0 ….
in the first post you mention the render speed of 2.0
is it significantly slower than 1.5 ? did anyone speed tests ?
maybe it is faster to work in 1.5 for some projects if the 2.0 features are not needed?
Mac Pro (2012) 2x6 Core | 24GB | 1 x Geforce GTX580/3GB
Displacement in Version 2.01.02 does not work well for me. For native C4D shader takes a very long time to execute the operation (Shader C4d Render to Texture) .. If the operation is interrupted, the cinema 4d crashes. In the previous version I had with native shaders no problem.
ASUS P6X58D-E / Nvidia GeForce GTX 780 / 24GB Ram (DDR3) / i7 950 (OC4.2Ghz-without HT) / Windows 7 x64 / and million cooling fans
VFX/CGI, Animation for documentary movies, Music videos, Products renderings, Advertising....3D/2D (small production)
because it uses displacement's resolution for rendering the native shadersMethod wrote:Hi,
Hi, I found something strange. When I activate render region, the zone that is updating isnt exactly the square that I drew, its slightly displaced... its normal?
intel i7 3770k // 2 x Evga Titan Superclocked 6gb Vram // 16gb RAM
http://www.octavioalonso.com
