Hello,
I am running into this issue randomly as I work with Octane. In some scene files it seems that I am getting a different result between the picture viewer and the live viewer. I'll attach the different renders, any help is appreciated.
live viewer and picture viewer rendering different results
what about your save image format and color profile? Also Renderbuffer type in render settings?
- sparkworld
Hmm yea I figured it must be something to do with color profile as the viewport is doing the same result as picture viewer. Frame buffer is set to 8 bit buffer. Color profile is sRGB. Linear workflow is checked on and input color profile is linear. Final render is being saved as a 8 bit png.
is your light sources object or arealights? I see glows are different.
- sparkworld
The neon lights are octane blackbody emission materials with a color in the distribution channel. Using HDR light studio for lighting. No area lights.
- sparkworld
Ok so after some further testing, it doesn't seem to be color profile or render buffer settings. When I turn off all geometry but car and the HDR I get accurate renders between picture viewer and live viewer. Once I turn on the floor, wall and neon lights geometry I get the difference in results in the renders.
- sparkworld
Ok after further troubleshooting, it came down to the cloner object and the render instances checkbox. Once I turned it on the render was the same.
Can you give me the scene without car to explain what's wrong.
There is a issue for emissive materials. This works with some normalization over attached surfaces. If you have not a objecttag, all objects will collected to a single mesh. This causes some different illumination on different amount objects. But if you use a objecttag for this objects, every object will exported as indivual with some tranformation node. This provides exact illuminations as arealights
ok, solution is that:
choice method: Resend only updated objects
and
Update method: faster updates
This combination is exactly like as Live Viewer(interactive mode)
if you leave the "update method" as faster rendering, all objects in a same object no. They are collected to a single mesh in rendering. This causes different results.
I THINK that's time to retire the "faster renders" update method
and
