Focus Depth bug
Seems Focus Depth (autofocus) doesn't work properly. I checked szene file.
							PURE3D Visualisierungen
Same here. After one switch to manual mode, it is stuck in it. No more autofocus at all.
PS: 3dsmax 2014, Ocatane v2.0a 11/06
							i7-4960K 4.2Ghz, 64Gb RAM, GTX1080Ti + GTX1080 + TitanX
+ x5 i7-4Ghz, 16Gb RAM
Win10, 3dsmax, Vray, Octane, Blackmagic Fusion, Unity, Fusion 360
You´re rightKarba wrote:It doesn't work with standard camera, but should work with octane one.DIO wrote:Also I´m not able to animate the focus with the focus picker anymore??
Just doesn´t set a key when changing focus.
Worked fine with 1.5
Works with octane camera. Thanks.
corei7-4930k 6 x 4,0 Ghz, 32GB RAM, 2x 980 Ti
Win7 64bit, 3dsmax 2014 / 2015
Yep. It works with octane camera. And as I see, it works in my other test scene. Should there be something with scene scale?..Karba wrote:It doesn't work with standard camera, but should work with octane one.
Anyway, I hope you will able to fix autofocus for using with viewports, without cameras. In my case it is really useful for fast scene navigation. And for models preview, while modeling, DOF looks charming
I think you just used octane camera without autofocus which replaces standard octane settings with autofocus.Dancem wrote:Yep. It works with octane camera. And as I see, it works in my other test scene. Should there be something with scene scale?..Karba wrote:It doesn't work with standard camera, but should work with octane one.
I only use it with viewport in 90% of all cases and it does not work. Even with objects without opacy.
