crashing when adjusting image sequence end frame
this
can you check imagesequence.c4d in http://render.otoy.com/customerdownload ... amples.zip
it has imagetexture and normal bitmap usage
miohn
strange!
this file is working!
With the c4d-bitmap and also with the octane image texture.
I see both counts animated in LiveViewer.
But as soon as I load my image sequence ....
Checked again: its a RGB tiff image-sequence (also tried with rgb jgps) which works well as a "single" image,
but not with image sequence. As soon as I set the range my texture disappears
complete system restore maybe?
MIke
can you remove 02_ from name? it can cause to understand wrong ranges.
miohn
no! still blank!
I don't know whats wrong with these images.
When I load a normal "wood" bitmap f.e. it appears in LiveViewer. Just as usual.
But these Images (jpg, 8 bit, RGB, 1920x1008 px) are blank in LiveViewer, in MaterialManager and in normal c4d View.
But it must have to do something with the images I think.
regards
Mike
ok, try other sequences. Or convert to other format. I have no idea about them.
miohn
well, this all seams a bit strange.
Since 2 or 3 months I have major problems with msvcr-dlls and since
I tried the newest NVidia-Driver my system is very unstable.
Will now rebuild my system with system-image and hope!
thanks for your support!
Mike
