Version 2.05.0 - Updated on (14.08.14)
MINGATU wrote:Heres the report I got from the error. It's saying there's a problem with the r14.dylib
This is from the 2.00.xx Mac plugin.
hmm, but plugin is working. I thought that's not loading. So we are looking to wrong direction.
Can you try removing other plugins, Hot4d also? Which action is causing to this crash?
MINGATU
I removed every plugin except for the attached grab and it still crashing.
MINGATU
Hey Aoktar,
Also, running C4D r14.042 (Build RC76788) if that helps with anything.
Thank you for the help!
MINGATU wrote:Hey Aoktar,
I'm going to check tomorrow on Macos. Something can be wrong on packed files.
tkkim
Octane for C4D 2.0 Mac version has some errors in Mograph.
I attach test file(image).
The railroad is cloner with object mode. And the object is spline.
If spline is straight, there is no problem. But if spline is curve, some instances is gone.
The train is cloner too.
Each train follow same curve spline.
In some position, train is gone.
There is no motion blur.
Octane2test.zip
(390.15 KiB) Downloaded 252 times
tkkim wrote:Octane for C4D 2.0 Mac version has some errors in Mograph.
is this happening in Picture Viewer?
Did you put objecttag over the top of train group? And did you selected "Resen only updated objects" + "faster updates"?
Can you check my sample scene? It shows correct usages of dynamic geometry with static scenes. Also has motion blur is activated on objects
shot_26.rar
(606.15 KiB) Downloaded 252 times
tkkim
I will attach c4d file.
Please play the file and compare Perspective window with Live Viewer.
mographError.c4d.zip
(115.5 KiB) Downloaded 232 times
tkkim
Hi, aoktar
Thank you for your sample file.
But, Some containers disappear in my Mac.
I can see all container in perspective view window.
But, some container disappaer in Live viewer window.
MINGATU
Hey Tkkim,
I'm curious what specs u have running octane 2 on the mac. I"m trying to get it to work but it keeps crashing on launch.
OS 10.9.3
Nvidia Geforce 680 Mac Edition
Nvidia webDriver 334.01.01f01
Cinema4D r14.042 (build RC79788)
MINGATU wrote:Hey Tkkim,
OS 10.9.3
Hi MINGATU,
i checked r14 on macos. It's working here. But i notified some problem while checking Tkkim's scene. Macos version could have some serious problem with libs. Let me to continue testing, i'm going to give some info soon.
