No devices to render found.
mbetke
I don't get any of my four Titan cards shown up in the devices section.
The error messenger shows this:
Started logging on 13.06.14 15:45:45
OctaneRender version 2.00 (2000010)
CUDA driver version is too low - can't use CUDA
Which driver version do I need to run it? At the moment I run driver version 314.09 and it worked fine even with the 2.0 beta.
PURE3D Visualisierungen
juanjgon
You need one of the last NVidia drivers to work with Octane 2.0. Simple upgrade to the last one available.
mbetke
Thanks. I'm a bit picky with graphic driver updates because sometimes they make things worse than better.
I will give the 337.88 ones a try.
marcomviana
I have a nvidia titan and a quadro fx 3800. simply the octane does not recognize any of the signs cuda. drive last 337.88 nvidia.
how to solve this problem?
3dsmax 2014
windows 8 64bits
intel dual xeon x5690
54gb ram
Return to “Autodesk 3Ds Max”
