Version 2.05.0 - Updated on (14.08.14)
- shawnfrueh
I've got the Daemons to show in the standalone but they all come up as "duplicate master" and I cannot enable them. Has anyone run into this problem?
yepshawnfrueh wrote:I've got the Daemons to show in the standalone but they all come up as "duplicate master" and I cannot enable them. Has anyone run into this problem?
have to restart my c4d and recheck network render in standalone
pxlntwrk.net
pxlntwrk.net
- shawnfrueh
That worked! this is seriously broken in standalonepxlntwrk wrote: yep
- shawnfrueh
I spoke to soon, its working in standalone now but cinema still does not show the extra gpus. I have copied over the .dat file but still nothing.
It shows up in the red text on top of live viewer as slaves. Also, you checked network render in octane?shawnfrueh wrote:I spoke to soon, its working in standalone now but cinema still does not show the extra gpus. I have copied over the .dat file but still nothing.
1 Dell Z840 with 2x Titan XP's
2 Digital Storm Hailstorm/Win8/32GB/EVGA Titan x4
2 Server blades with 4 Tesla K80's
- shawnfrueh
Yes, network rendering is checked in the dialog menu and I have restarted cinema but still it shows using 0 of 0.
and you have the daemon open on your slave comps?shawnfrueh wrote:Yes, network rendering is checked in the dialog menu and I have restarted cinema but still it shows using 0 of 0.
- shawnfrueh
Yes, and they work in standalone just fine. Just not in cinema.SVITAdmin wrote: and you have the daemon open on your slave comps?
here are my setup steps, I must be doing something wrong.
1. Install plugin
2. copy .dat file from plugins\c4doctane\Libs64_200 to the main cinema folder.
3. Get standalone to see and enable slaves.
4. turn on net rendering in cinema
5. restart cinema
6. open live viewer, render: Still says 0 of 0
- eyeonestudio
- Contact:
We Need NetRender Info & Setup Dialog Windowshawnfrueh wrote:Yes, and they work in standalone just fine. Just not in cinema.SVITAdmin wrote: and you have the daemon open on your slave comps?
1. Install plugin
5. restart cinema
Maybe He Can.. He Need time
C4D R2026 / Win11 / AMD TR WX Series / 256Gb RAM / RTX 5090 FE / 100GbE
Odd. i wish i could help. This setup worked for me.shawnfrueh wrote:Yes, and they work in standalone just fine. Just not in cinema.SVITAdmin wrote: and you have the daemon open on your slave comps?
1. Install plugin
5. restart cinema
