Version 2.05.0 - Updated on (14.08.14)
network rendering is working, but be sure SA can do it also. you can enable it from menu of live viewer. it's not so much tested by me.
immortal-arts did some tests with plugin.
R_Flash
Everything is fine. Plugn is work. But how can I get my 39 euro back payed by mistake for upgrade?
Win7, i7 950, 12Gb RAM, GTX580
LudovicRouy wrote:Thanks a lot for your great job Aoktar !
I love the displacement with parametric shaders (I use Enhance C4D) it works like a charm and gives great patterns !
Its just amazing !
looks great and as a vector displacement
eyeonestudio
aoktar wrote:network rendering is working, but be sure SA can do it also. you can enable it from menu of live viewer. it's not so much tested by me.
Ok....
Check Network Rendering All sub machine. Master Machine too.
Nothing speed up..... Live & Picture viwer...
Next
Install Daemon All Submachine.
Standalone can find submachine & Speed up.
But C4D is not. Same Speed...
c4d Nothing info & setting. only Network rendering Check Menu. It's Confused
AM I MISSING?
:oops:
Maybe Scan Subnet. I guess
See Octane Standalone
C4D R2026 / Win11 / AMD TR WX Series / 256Gb RAM / RTX 5090 FE / 100GbE
dinf
*push*
Displacement:
- eg. loading a noise, it makes visible steps and spikes. Is there an easy way to get rid of them?
- loading a texture does not show up in live viewer info lines as a loaded map. So it is processed before?
- loading a 32 bit floating tif does not show any response.
The 32 Bit Tif is a special one, a geotiff. Probably thats the point. Sometimes it seems that Cinema itself can handle it, sometimes not.
e.g. noise, its a 1/10 part of a standard C4D noise in 8k. Is there a way to smooth it?
| Win 11 | 64 GB RAM | AMD 5900X | RTX 3090 24 GB | C4D R21 | C4D-Octane v2026.1 |
ASyme1
Hi Ahmet!
Sweet upgrade man! I'm loving this new version. Really great job. Can't stop playing with this. I do have a question regarding displacement. When using a displacement texture it's breaking my geometry. See attached. Maybe I'm missing a check box. Can you clue me in here?
Thanks again. LOVE 2.0.
alec
Alec Syme
http://www.fuseanimation.com
-Gigabyte X79-UP4 - Intel i7 3930 3.4 - Windows 8.1 Pro 64bit - EVGA TITAN X7 - 32 Gigs Corsair 1600 4 channel RAM -
ten
ASyme1 wrote:Hi Ahmet!
alec
I think you need some black edges around the texture to make them connect. If everything is white or light grey they all will be displaced..... I think...
ten
( PC ) i7 5960x octal 4.5ghz / 64GB / 2x Titan X 12GB / 1x 780 6GB - ( Laptop ) i7 4790k 4ghz / 32GB / 980M 8GB - Octane CD4 2.x / C4DR16.x / win 8.x
eyeonestudio
alec
C4D Displacement Channel : Keep Origian Edges Option
VRAY Displacement Meterial : Keep Continuity Option
Octane 2.0 Need This Option. Standalone too... ;) Maybe Can't
but you can change Image.
abstrax
Ok....
Next
AM I MISSING?
:oops:
Yes, the daemon is in the 192.168.0.0/24 sub-net. You have to switch to this one, to be able to find the daemon. See here in the Standalone manual: http://render.otoy.com/manuals/Standalo ... ge_id=1248
To switch the sub-net you have to disable network rendering first:
http://render.otoy.com/manuals/Standalo ... ge_id=1258
pxlntwrk
Ok....
Next
AM I MISSING?
:oops:
hello,
its works here but not seamless..
on master when octane c4d is on, try to check uncheck check "enable network rendering" in standalone pref menu.... :cry:
pxlntwrk.net
