OctaneRender™ for Blender 1.53 - 4.9 beta Win [OBSOLETE]
enricocerica
JimStar wrote:
enricocerica wrote:Any idea ?
Enrico, I need a little more detailed description to be able to reproduce it.
Can you please describe step by step what should I do to reproduce and in what exact moment of these steps you get the crash?
I sent you a PM
Cheers
Modeling system : I7 32GB Windows 10 & Fujitsu Celsius H720
GPU : 1x Gigabyte GTX580 3GB + 1x MSI GTX780 3GB + 1x PALIT GTX780 6GB +1x Asus Stix GTX1070 8GB
http://www.myline.be
resmas
resmas wrote:Hello there Jim, i think i found a bug, or im doing something wrong.
When i export a dissolve animation to alembic file and then open in octane, the materials go a bit crazy.
There are only 3 materials in blender file, and the alembic file has 3 nodes that I set with 3 different materials, but when you run the timeline in octane they change position, and new materials are displayed, when I cannot select them... :shock:
The easy way is to open the Octane file and see for yourself, I have attached both the ocs file and the .blend so you might take a look.
cheers
resmas
hello again Jim, did you have time to analise my problem?
cheers
resmas
i7-2600k | SSD Vertex 3 | WD Velociraptor | WS Revolution | 16GB Ram HyperX | PSU LEPA G1600W | 3 X Asus GTX590 |
https://pt-pt.facebook.com/arq.resmas
voon
1.55? :)
JimStar
Guys, be patient. I'm working on Maya plugin now, Maya users waited a long time during I was improving Blender plugin...
MattRM
JimStar wrote:Guys, be patient. I'm working on Maya plugin now, Maya users waited a long time during I was improving Blender plugin...
Hi JimStar,
Understood you're working on an other plugins but... The bug from Blender Octane about building the texture, published by other peoples, not only me is still present... 2 versions update after in worth (before just increment the filename solved the issue, now no more, when Octane Server wants to build the texture, and completly random...)... I just spent 45 min to have my texture build correctly... solved by open an other Blender Octane (in parallel) :shock:
45 min to build correctly a texture for a render engine... including in beta... something wrong... I understand the "beta", but I worked before with a "beta" engine to make "The Little Prince 3D serie"... We had problem of course, but not for building and refreshing correctly a texture...
I'm quite angry but understand that you need to work too an maya plugins, Octane 2.0... but this bug is really really boring...
Matt
ps : It's for a professional work, that's why I'm quite angry (send the video of the bug in private message few time ago)
voon
WHOA! We just went 2.x .... :-) So, forget 1.55 *g*
JimStar
Next version HERE.
Return to “Blender”
