Octane+Noise Ninja
I was making some tests with Noise Ninja. Great tool for reducing noise. In this case I merged the noise and denoised image so I don´t loose detail in some textures. Worth to take a look at this kind of plugins. First image is the proccessed image, second one is the original.
Yes it can loose detail depending on the intensity of the filter. I guess a good method would be having a material ID pass so you can select which areas will get the effect and with how much intensity, maybe overall supported by an AAOO pass to bring back the missing areas. I should make some tests, but in general, it looks a very nice software to work with.
- LudovicRouy
- Contact:
Here I use Akvis Noise buster and it gives good results too
I prefer rendering higher res & using inbuild parameters inside OctaneRender, 'cos afterwords the progam applies post production.
If You get to denoise image later You make too much damage (for the the image & in lower resolution that is very vissible).
Might be faster faster (I agree) though I'd personaly rather choose quality over speed (with no extra tools, but Octane only).
(Wrote about this a while ago, if someOne interested http://tomglimps.com/lounge-chair-downl ... ne-render/)
The only time we really use it is for Animations. We figure out how many samples we need to clean up the image to a good amount and then use neat video to finish it up. We did a lot of comparison images and it really works well. You can't use it as a replacement, but we were able to render our animations at 3k samples vs 10k. At 3k, pretty much everything was clean except a couple small areas. And a little bit of neat video had no negative impact since 99% of the image was clean.
Over a 2 min long animation, it saved us days of rendering.
