hi all I would like to retrieve aef model (model Artlantis)
I export from obj file in Artlantis. I have a. mtl and a folder with the file contents, but when I import in octane render I have my 3d model with only one subject.
I test a model to export sketchup materials but also disappear.
I would like to retrieve an entire library of vegetation.
Do you have a solution?
thank you
Import .Obj in Octane Render?
Read the start of the OBJ file in a test editor.
It shows the expected relative path to the MTL file - usually it's just the file name as it is in the same folder as the OBJ [e.g. "objname.mtl"].
Read the MTL file in a text editor.
It shows the expected relative paths for any image files used for textures, usually in a sub-folder that is kept with the MTL file [e.g. "Textures/leaf666.png"].
Ensure that the files and subfolder/images are correctly located relative to each other, and that the OBJ/MTL files correctly refer to the relative paths...
TIG
- Interfaces
TIG thank you for your help. I can test. I inform you if it works.
I have a request for better visibility forum for new come example: would be possible to put the valid plugin at the top of the list
see example: THANKS.
