Octane for Softimage 1.02 RC1 [Obsolete]
Gescort
Hi, Face!
xsi2015 - black preview render and region render, but render status is progress
xsi2013 - works correctly
face
Try to change the display to 8bit.
So much i remember, you can do it in the color management under the preferences.
Haven´t a licens for 2015, so i can´t check it now.
face
http://vimeo.com/user2509578
Gescort
Сolor management did not help or I do not understand how to change it. Also I final rendered picture in EXR and it is white, but on compositing find color information.
While testing xsi2013. New texture projection system great and very quickly for using :D
face
I wait for my 2015 license to test it. Without it, i can´t give you a help.
Think it have something to do with the bit depth which Softimage requested for the preview window.
I can test it with 2013 but because it is difference, i want to test it in 2015.
Sorry for that trouble,
face
Gescort
Thank you!
Your work is very difficult and is very valuable to us!!!
face
Thank you ;)
I think i have found the problem. I define different bit depths, which are 8, 16 and 32bit.
The 32bit isn´t used. On 2013 and 2014, which i use to test, all works fine because the standard is 8bit and you can switch it to 16bit over the color management.
Maybe on 2015 the highest bit depth is used, which will be the defined but unused 32bit.
Have disabled it now and hope it works.
To test, you can download the plugin dll and replace it with the one in the addon directory.
If it works, i will update the addon in the first post.
face
octane_internal_2012.zip
(947.5 KiB) Downloaded 446 times
Gescort
Perfect!!!
That is work.
In xsi2015 also I changed Color Management - Render Pass and Preview for correct gamma view in preview window and gamma correct my image after saving.
face
Ok, now i have also my SI2015 license so i can play around.
Will try to become the same result as in SI2013 without to tweek the gamma.
face
ps:
Your image looks realy cool. Looks like the Nintendo´s Yoshi ;)
Gescort
Thanks))
It would be very cool!
face
The saved image should looks the same or im wrong?
face
Return to “Autodesk Softimage XSI”
