PolyFX + Octane ObjectTag Causes Crash Every Time
Iksmada
I have an animation where only a few objects are moving (these objects use Mograph PolyFX with a plain effector animated to reveal the objects).
To render faster I set OctaneC4D to 'Resend only Updated Objects'. However the Octane ObjectTags, placed on each object which has a PolyFX effector, causes Cinema 4D to crash as soon as it starts to render, and the Octane C4D plugin is referenced in the error message. No settings are changed on the ObjectTag, apart from the mesh no. for each object.
It only seems to happen when the Octane ObjectTag is placed on a PolyFX object. If I remove the tag, it renders without crashing, but of course the moving objects do not render unless I change the render setting to 'Send All Scene Data'. This takes about 2 minutes extra per frame, so is far from ideal.
I have replicated this in different tests and it always seems that if an Octane ObjectTag is placed on a PolyFX object it crashes Cinema when starting rendering. Placing the PolyFX object in a Null and putting the ObjectTag on that makes no difference.
The ObjectTag works fine on other objects I have tested.
Spec: Win 7 Pro x64 (clean install) C4D R15 (clean install, no plugins), OctaneC4D 1.52.1, Intel E5-2690 2x10 core Xeons, 64GB RAM, 2xTitan Black GPUs
Thanks in advance!
can you give me your scene? I can't generate crash here
Iksmada
Hey Aoktar,
Thanks for replying - I will send the file right now.
I copied the animation into a new file for you - as soon as you hit render it should crash C4D.
Delete the Octane ObjectTag and it should work.
Hope you can help!
Cheers,
Iksmada
It's ok on my computer. Can you check picture?
Iksmada
Sorry for the late reply; the problem is now resolved on that system, and although it still happens on another PC I don't need to fix it on that one.
Thanks for your help aoktar :-)
ten
What was the fix please? Anything others should be aware of ?
ten
( PC ) i7 5960x octal 4.5ghz / 64GB / 2x Titan X 12GB / 1x 780 6GB - ( Laptop ) i7 4790k 4ghz / 32GB / 980M 8GB - Octane CD4 2.x / C4DR16.x / win 8.x
ten wrote:What was the fix please? Anything others should be aware of ?
ten
nothing. It doesn't crashes on 1.53.
