OctaneRender™ for Blender 1.52 - 4.8 beta Win [OBSOLETE]
JimStar
OctaneRender™ for Blender plugin. Windows x64 version.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one. To stop the server - just right-click its icon in the tray.
  • Fixed bug with big alembic files (ROUBAL reported).
Blender Octane Edition - 1.52 - 4.8 beta (2.70) (58.9MB autoinstaller file)
Octane Server - 1.52 - 4.8 beta (7.8MB autoinstaller file)
kavorka
Awesome!
Gonna check to see if this fixes my alembic problems too
ROUBAL
Thank you very much ! Starting download right now !
kavorka
Hey Jimstar,
This is still giving me a lot of camera shaking.
If I render in the plugin, its nice and smooth, but if I export via alembic, it is very shaky.
Is this a problem with the stand alone import or the Blender export?
ROUBAL
I have tested alembic export on 990 frames with both my simple cubes animation and my animated plane tree. In both test, the alembic file is present in the Output folder, and it is valid. I will do an export of 990 frames of my complex car animation tomorrow to be sure, but so far it works !
So, a big THANK YOU Jim ! :)
I noticed 3 things :
1 - Materials Pins names are different than before : Instead of Mesh-MaterialName, they are displayed __m_MaterialName
2 - The Viewport hide priority doesn't hide the camera. Even if Hidden and placed on a layer not selected for render, it is present in the alembic node.
I can export the camera only, but not geometry without a camera.
3 -The exports seem to work properly, but there are error lines in the Blender console :
Any comment about these behaviours ?
voon
Only a small cosmetic thing atm. There's something funky going on wit the fonts/characters at install time (see attachment). Also I think I only saw 2013 mentioned on the spider picture when you launch the install exe .. :)
JimStar
kavorka wrote:Hey Jimstar,
This is the cam direction precision problem inside core alembic code, not in the plugin. Roeland is aware of it.
To look at the reason, after exporting alembic file and opening it in standalone - you can check camera target-position numbers inside standalone when moving towards time-line. The difference between numbers is too small, so this leads to lack of precision...
JimStar
ROUBAL wrote:1 - Materials Pins names are different than before : Instead of Mesh-MaterialName, they are displayed __m_MaterialName
Do you like the new mesh visibility features?.. Pay for it by some more ugly names. :mrgreen:
ROUBAL wrote:2 - The Viewport hide priority doesn't hide the camera. Even if Hidden and placed on a layer not selected for render, it is present in the alembic node.
I will check it.
ROUBAL wrote:3 -The exports seem to work properly, but there are error lines in the Blender console
I will need the scene to reproduce it...
ROUBAL
@ Jim : It is the same scene I already sent you with the animated tree. I only changed the name of the materials, because I noticed afterward that they were ununderstandable alphanumeric names (inherited from textures references generated by Onyx Garden) instead of clear names like Trunk and Leaves.
EDIT : I ran again this export of the 990 frames animated tree... I came back one hour later, and it had stopped at frame 14 without error message in the console. Blender for Octane is frozen. i have to kill the server to close Blender. :cry:
I started everything again, and launched a new export... The export stopped at frame 140 with no error message in the console. Blender was frozen again. Some lines have been added with error messages when I killed the server.
I send you the scene in PM. It is the animated tree with new materials names.
JimStar
ROUBAL
How do you start the render? Do you still enter the login/pass before it?..
Return to “Blender”
